Old 12-31-2010, 02:36 PM   #1
Squareforceone
Squareforceone's Avatar
Tachs in automatics?
I see a lot of people on here with tachometers in there trucks, and a lot of them are automatics. I know that in a manual you can you use it to help with shifts but what exactly do you use it for in an automatic? Or do people just like to have an idea what RPM there motors at?
Squareforceone is offline   Reply With Quote
Old 12-31-2010, 02:39 PM   #2
codydubb
codydubb's Avatar
Re: Tachs in automatics?
Use it for the same thing in an automatic that you would a manual
1985 Chevy C10
350 .60 over iron eagle h-beam rods, sealed power high comp pistons, forged crank, vortec heads, edelbrock performer rpm vortec intake, roller rockers, .488 .510 cam 750 Demon Double Pumper, Longtube headers, Dual Flowmaster exhaust,Dual electric fans, Proform electric water pump. TCI 3500 Stall Converter th350 trans B&M shift kit 10 bolt 3.73 Detroit Locker
codydubb is offline   Reply With Quote
Old 12-31-2010, 02:43 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
It's just kool seeing that little needle move when you push the gas !
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 12-31-2010, 02:50 PM   #4
Squareforceone
Lol thats good enough for me i just didn't know if i was missing something because i see a lot of people just put one stick on the dash where IMO it just looks out of place i would just rather not do that unless there was use for it
Old 12-31-2010, 03:18 PM   #5
83burban
helps with tuning...other than that...I like looking at it jump when I really get on it.
83burban is offline   Reply With Quote
Old 12-31-2010, 03:43 PM   #6
Benelli
Watchin the rust grow
Benelli's Avatar
I like to watch it when I kick-down or when pulling trailers and it helps you keep a light foot when your trying to save fuel.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 12-31-2010, 04:12 PM   #7
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I had one in an old truck , on trips I'd set the cruise at 2000 in hopes of better MPG.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 12-31-2010, 04:22 PM   #8
69GMC910
MOTORHEAD!
69GMC910's Avatar
My speedo is way off... I know 2750rpm is 60mph... I rarely use the speedometer!!!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 12-31-2010, 04:28 PM   #9
Jonboy
Slots go on anything!
That's why I added one, too.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 12-31-2010, 04:49 PM   #10
canadian trucker
A day should have 30 hours.
I just like seeing the needle hit 9000 rpm. On a V8 it sounds amazing.
canadian trucker is offline   Reply With Quote
Old 12-31-2010, 05:35 PM   #11
ont_guy_38
ont_guy_38's Avatar
With a stock engine it's not as huge of a deal but as soon as you start adding cams , headers, carbs or any other higher performance product that usually also gets your rpm higher so you want to be able to keep an eye on it as you can soon over rev your engine
ont_guy_38 is offline   Reply With Quote
Old 12-31-2010, 05:53 PM   #12
evan
evan's Avatar
I got mine as soon as I took out the stock 305 and installed a rebuilt 350. Needed it to make sure I was breaking in the cam properly and wouldn't go back.
Evan B.
evan is offline   Reply With Quote
Old 01-01-2011, 01:00 AM   #13
Psycho71
Psycho71's Avatar
I use mi e for the exact same reason.
And on the later model vehicles i like them because i can keep an eye on it and know when the converter locks and unlocks.
For performance engines, shift points, tuning, and the ever important "cool factor".
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 01-01-2011, 10:08 AM   #14
PRattenbury
I agree with the above. I can keep an eye on when the converter is locking and unlocking, and how much RPM drop there is when it does. It would be handy for cam break-in, often as that happens. And also for tuning/setting the idle. And yeah, it's just generally cool to have.
PRattenbury is offline   Reply With Quote
Old 01-01-2011, 12:18 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
I have one simply because they were an option in 77 and it looks good in my dash
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-01-2011, 12:53 PM   #16
lakeroadster
Other than the obvious benefits during tuning....
Ever had a clutch wear out or an automatic transmission start slipping and need repaired / replaced? The tachometer will help you to determine this at the onset of the problem.
Drive in the snow or on slick roads? If you accelerate and are mindful of the tachometer you can tell if your tire(s) spinning.
Ever do a burnout? The tachometer will help you to keep from over revving the engine.
Ever manually shift an automatic? The tachometer lets you hit your shift points.
lakeroadster is offline   Reply With Quote
Old 01-03-2011, 07:16 PM   #17
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
that would make a cool garage poster or photo N2TRUX!
"san diego chargers #1"
joe1982 is offline   Reply With Quote
Old 01-03-2011, 07:49 PM   #18
sailed2japan
Jonny
sailed2japan's Avatar
but with the needles pointing to the other side
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 01-03-2011, 08:31 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Hmmm? Not a bad idea. My wife had a nice pic blown up for me for a Christmas present. That would compliment it rather nicely.
Articles-
"Refining Sierra"
Old 01-03-2011, 08:54 PM   #20
Shawn5488
I like the factory tach because having that huge gas gauge is ugly, the tach looks great there.
Shawn5488 is offline   Reply With Quote
Old 01-03-2011, 09:32 PM   #21
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
i like the looks
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 01-03-2011, 10:46 PM   #22
bmchevy1979
bmchevy1979's Avatar
with all of points made heck if it wasn't for the tach in my grandpa's 90 F350 we would have destroyed the motor (lost all gears going 75 mph down freeway towing backhoe) another save is when I was climbing a hill in my blazer I realized I was about to over rev the engine because I was spinning my tires
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 01-03-2011, 11:13 PM   #23
48cj2a
48cj2a's Avatar
Were they still available in 88-91 Blazers and Burb'ns?
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
Old 01-04-2011, 12:35 AM   #24
johnnypop
My family hits the sand dunes pretty often and it helps a lot in dragging big toys out... I always watch it to make sure I'm not going to blow the motor since it's easy to do in sand and mud. It spends a lot of off-road time in 4 low, so it spins up really quick.
johnnypop is offline   Reply With Quote
Old 01-04-2011, 10:02 AM   #25
willett
Another Day, Another Dollar
willett's Avatar
i have one so that i know what the hell is going on when the tunes are so loud my ears bleed
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
