Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-01-2011, 06:22 PM   #1
messer007
messer007's Avatar
Which will work better if either at all
Just wondering which one would be strong enough to run a blaster I'm needing to upgrade compressors and I wanna get one that be enough for a blaster and painting and running air tools...I don't know if either will work so some advice from someone who knows what they r talking bout would be grateful
http://www.tractorsupply.com/tools/a...r-5-hp-3496129
http://www.tractorsupply.com/tools/a...ressor-3301332
1970 C-10 CST
2003 Silverado
2004 Avalanche LTZ
messer007 is offline   Reply With Quote
Old 01-01-2011, 09:18 PM   #2
brans72
Re: Which will work better if either at all
I have the second compressor and it is ok and I use a blasting cabinet but if I where to do it again least step up to first compressor you posted. My compressor does cut on a bit more then I like and think it should be little more stronger then it is but it's what I got for now.
brans72 is offline   Reply With Quote
Old 01-01-2011, 09:25 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
Compressor size will depend on the blaster size your wanting to use.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-01-2011, 10:24 PM   #4
messer007
messer007's Avatar
Just thinking bout buying one from harbor freight...does anybody recommend one From
There or is it a waste of money is there any other brands I should look at
1970 C-10 CST
2003 Silverado
2004 Avalanche LTZ
Old 01-02-2011, 10:01 AM   #5
brans72
I bought the one from H/F due to my budget. So far can't complain really does pretty good job with right media. Things I wish where different - better lighting,glass you will change protector cover alot depending on blasting,ledge when opening door media stays on and it falls out when open the door, media will stick to sides etc and not drop back down ( just shot it with gun then ok). Blasted probably 100 parts so far can't really complain for $180 I paid for it. Also picked media up from Northern Tools called Black Diamond 8.00 bag and use safety always when blasting - get a respirator mask. Just my .02
Old 01-02-2011, 10:38 AM   #6
KSCHEVYUP
KSCHEVYUP's Avatar
I would definitely get the 2-stage compressor if it were me.
I wish I had that one. Matter of fact that is exactly the same model I have been looking at the local Tractor Supply.
My single stage compressor runs way to much
trying to keep up with my blaster and I am probably going to burn it up?
Ron
1972 C30 Cheyenne Super
1971 C10 (Parts truck)
KSCHEVYUP is offline   Reply With Quote
Old 01-02-2011, 11:05 AM   #7
Restrorob
Restrorob's Avatar
Yep, The two stage is a better choice....
My single stage 80 gal runs almost continuously with my roll around Matco bucket style blaster, I was worried about over heating as well.
I tapped into one side of the 220 on the pressure switch with a 110 pigtail, Now when I blast I set a box fan up to move more air over the compressor.
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
