Aftermarket brakes
Are any of you guys running a aftermarket brake kit? And are you using them in the street also?
Flowershop Hip Hop & Street Rods Dropmember 83 Custom Deluxe Almond on Almond 85 Silverado White on Red/Now Chevy LeMans Blue Rendering in Truckin magazine vol 36 no. 11,2010 |
Re: Aftermarket brakes
yeap. strange race dual piston race brakes front and rear
72 SUPER10 |
Registered Truck Offender
Put a set of heavy 74 stock disks on the front, and Willwood 4piston disks on the rear. Stops fast enough that I always look in the rear view to see whats behind me and if there paying attention!
Carefull tho, not having an emergency brake is illegal in some states, and a significant SCARE if something happens to your pedal / mastercylinder / braking system.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
![]() Join Date: Jan 2008
I run stock discs with ceramic pads in the front, and Aerospace in the rear, with the correct proportioning block. Like Marv said, keep an eye in the rearview!
helped my buddy bolt on a full set of aerospace kit on a customers monza and it got me to thinking,those things a f'n light!
It's Better With Nitro
Yes, I've run Lamb, Mark Williams and Wilwood kits. I run Mark Williams' rear kits of late since I use his symmetrical housing ends of the majority of my projects. I am currently running Wilwood 6-piston calipers on my front brakes with stock-style vented rotors.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
