Old 01-05-2011, 03:11 PM   #1
spudz
spudz's Avatar
1 Ton front crossmember in 1/2 ton??
OK I am gettin a lwb square on trade. Runs good, th350 needs a rebuild etc. Base model truck. I want to put 1 ton suspension under it. Is it as simple as unbolt a 1 ton crossmember and bolt it under the 1/2 ton? I know the 1/2 ton frames are thinner in gauge and shorter in height. How about the rear? Are the springs different lengths? I seen a thread about putting a 1 ton front end under a 1/2 ton not too long ago. I cant find it for hell now.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 01-05-2011, 06:48 PM   #2
87 chevy silverado
Re: 1 Ton front crossmember in 1/2 ton??
give me a min
87 chevy silverado is offline   Reply With Quote
Old 01-05-2011, 07:00 PM   #3
87 chevy silverado
cant find it eighter
Old 01-05-2011, 07:47 PM   #4
OJOE
Crew Cut
OJOE's Avatar
the front will swap over no problem. dont know about the rear
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 01-05-2011, 07:52 PM   #5
70BLAZERX2
Yes front susp. will bolt right up..you can even put the ton front susp..under a 67-72 frame..bolts right up to them..less 2 bolts..
I have a front ton susp out of a 2wd 87 crew cab dually here..$100..Only thing is the calipers are gone..rotors and everything else is there..
70BLAZERX2 is offline   Reply With Quote
Old 01-05-2011, 07:56 PM   #6
spudz
spudz's Avatar
I got a good line on 1 ton front end and rear springs. But if it falls threw I will let ya know
Old 01-05-2011, 08:01 PM   #7
70BLAZERX2
I save everything....LOL
Old 01-05-2011, 08:10 PM   #8
spudz
spudz's Avatar
Me too. Wife hates my junk. I am not making it a dually tho. Just single rear wheel 1 ton stuff.
Old 01-05-2011, 09:15 PM   #9
87 chevy silverado
pics?
Old 01-05-2011, 10:36 PM   #10
spudz
spudz's Avatar
I havent gotten the truck home yet. Hopefully before the weekend and I will take pics then!
Old 01-06-2011, 01:43 AM   #11
Mattman2010
Mattman2010's Avatar
If you use a 3/4 ton 14bolt instead of a 1 ton 14 bolt then the rear axle should just bolt right up. I believe the one tons have the spring perches closer to the frame (I know the D70HD dually axle I have has the springs mounted closer to the frame, i know your not going dually, im just saying).
So really if you get the whole 1 ton front suspension and a 3/4 ton 14 bolt for the rear it should just bolt on!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 01-06-2011, 06:03 AM   #12
Dru
hehe.
Im guessing it was my thread that was being referred to, my 1/2 ton frame was actually a 1/2 inch taller in the crossmember section than the 1 ton frame, so the brackets that set on the inside of the frame weren't usable, but hey I get to rip it all out again anyhow after discovering a bent frame.
Hope your swap goes well spudz, post some pics too please, I haven't got to the rear of mine yet, but will have to when I put a new 1 ton frame under it.
Dru is offline   Reply With Quote
Old 01-06-2011, 12:52 PM   #13
spudz
spudz's Avatar
Ok here ya go, I had my buddy who is bringing me the truck tonight snap a pic. He has it loaded up and ready to go. I am going to ATEMPT to rebuild this transmission myself. Ive never been into a th350. BUT cant be any harder then 700/4l60s.
Old 01-06-2011, 12:59 PM   #14
spudz
spudz's Avatar
Originally Posted by Dru View Post
hehe.
YEAH! it was you. Not sure what you mean by the inside brackets.. Could you explain what you had to do to overcome it?
Old 02-10-2011, 12:08 AM   #15
87 chevy silverado
thats a nice truck
Old 02-10-2011, 12:12 AM   #16
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Both front and rear will work if its a SRW. Remember Blazer/4x4 guys swap 1 tons all the time.
By inside brackets he means the ones the go from the frame to the crossmember. 1 tons have taller frame rails.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
