Old 01-05-2011, 05:13 PM   #1
72timemachine
does my 1981 Dana 44 have a solid axle?
Please do not move this thread to the 4x4 section I am having no luck there with my other past question so perhaps I will have a better shot here.
The truck is a 1981 Chevy Scottsdale 20 with a 350 ci. th400 mated to a 208 transfer case and 14 bolt (pan cover) rear end.
If I do have a solid axle which has 8 lug locking hubs and the 14 bolt rear end does that mean this is a more sought after front differential?
I am not sure if it is true but read that a solid axle Dana 44 can exceed the strength of a Dana 60????
Thanks for any help ahead of time,
72timemachine is offline   Reply With Quote
Old 01-05-2011, 05:33 PM   #2
Mattman2010
Mattman2010's Avatar
Re: does my 1981 Dana 44 have a solid axle?
No the dana 44 is not as strong as the dana 60. The dana 60's are the ones they put onto the 1 ton 4x4 trucks. The 14 bolt is a strong rear end, they where used in the k20's and 30's some where single wheel, and some where dually. The dana 44's came in both 6 and 8 lug, they are stronger than the 10 bolt that came in the front of some k10's and k20's, but they are not stronger than a dana 60. You cant get a stronger axle than the dana 60 front axle for these trucks that bolts right in!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 01-05-2011, 05:42 PM   #3
Doug_J
Doug_J's Avatar
And are you wanting to know if you have a solid front axle? If so you for sure do. They started using (IFS) indapendent front suspension in 88 up 4x4s.
Doug_J is offline   Reply With Quote
Old 01-05-2011, 05:49 PM   #4
72timemachine
Thanks two both you guys. Any idea if a 1981 th400 4x4 will bolt up to a 1990 np241 transfer case? One guy I spoke to said that after 1986-87 they shortened the th400 4x4 output shaft by 1" although he cannot be certain.
Again thank you.
Old 01-05-2011, 06:19 PM   #5
benoit454
Chris
benoit454's Avatar
I think you need a special adapter to make the th400 bolt to a 241 case. is the 90 case even the correct side drop? most of the older chevys have PS drop and the newer trucks have DS drop.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 01-05-2011, 07:06 PM   #6
87 V20 Scottsdale
87 V20 Scottsdale's Avatar
benoit454 you're right the drop is on the wrong side; and in '81 the front axle would be a 10-bolt instead of a D44. Unless of course someone else has swapped axles out.
Andrew
1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10
1988 C1500 Scottsdale 305, 700R4, 3.08
1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10
87 V20 Scottsdale is offline   Reply With Quote
Old 01-05-2011, 07:42 PM   #7
Greenlee
Greenlee's Avatar
If your 1990 np241 is from a 3/4 ton Suburban, it should bolt right up to the Turbo 400 and it will have the passenger side drop. It it's from a newer body style truck it will have driver's side drop. If it's from a 90' half-ton Suburban or Blazer it will have the correct drop, but the spline count is different.
Greenlee is offline   Reply With Quote
