Old 01-05-2011, 11:05 PM   #1
skokie
skokie's Avatar
Horn problem
I have a grant wheel for my tilt column http://www.grantproducts.com/products/view/109/ and the problem that I am having is with the horn. I have it unplugged for now otherwise it will just honk until the battery is dead. The kit I was told to use is a 3163 and I have followed the instructions to the letter http://www.grantproducts.com/files/i...7508-00-01.pdf
Has anyone been seen this problem and been able to fix it?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 01-06-2011, 01:58 PM   #2
glider_6969
Re: Horn problem
Sounds like it's grounded somewhere, try this, may be a bit annoying to do but give it a try. ( you may want ear plugs) While everything is mounted plug the horns back in. Now start working backwards from the horn press button on the steering column, keep taking a piece apart until the horns stop, this might help narrow what is grounding them..
who would think a simple thing like a horn could be such a p i n a.
glider_6969 is offline   Reply With Quote
Old 01-06-2011, 02:10 PM   #3
1968CHEVYC10
1968CHEVYC10's Avatar
Re: Horn problem
My guess would be the horn press button, if it's not assembled right it would do that, are you able to push the button down?
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 01-06-2011, 02:13 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Horn problem
I agree it sounds like a ground problem, but you may be able to look for it without using earplugs or annoying the neighbors.
When the horn button is pushed, it sends a ground to the horn relay (under the dash). The relay then sends -12V to the horns. It will click audibly when it closes and when it releases.
Unplug the horns and listen for the relay to click while you chase the problem. If it helps, connect a test lamp to the wire that goes to the horns. If it is lit, the relay is closed and the horns would be blowing. If the light is off, the horns would also be off.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 01-06-2011, 02:24 PM   #5
cdowns
cdowns's Avatar
Re: Horn problem
grant wheels and beepers have been notoriously bad for the past 45years or so that i've had experience with them
agree that premature grounding is the cause
Old 01-06-2011, 03:53 PM   #6
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: Horn problem
Same thing I was gonna suggest, I thought of the test light idea but just used the clicking sound to get mine working right. The 1st time you put it together it makes your head hurt trying to figure out how to get everything in there right, but once you figure it out it's much easier the next time around.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-06-2011, 09:45 PM   #7
skokie
skokie's Avatar
Re: Horn problem
Thanks for the info folks. I will give it a shot in a few days and reply back.
68 build thread
