Old 01-05-2011, 08:01 PM   #51
lynnfield
The Waco Kid
lynnfield's Avatar
Re: Parting 72 Cheyenne Super
DDD
More cab pics
lynnfield is offline   Reply With Quote
Old 01-05-2011, 08:06 PM   #52
blap
blap's Avatar
Please put me in line for the air cleaner with spacer...and rear wheel tubs ...Thankyou
blap is offline   Reply With Quote
Old 01-05-2011, 08:21 PM   #53
lynnfield
The Waco Kid
lynnfield's Avatar
OK got to work on this some late last night and some more today.
Sharpie, I have pics of the gauges, emblems, and knobs. One stud on the "super" was broke on the side tha got hit, there might be enough to work with a barrel clip. Radiator hold downs are ok, it's just the uppers. I have you down for the lighter also, I'm assuming you want socket and all. I'll work on a total and send it to you
sjarrett71, radio works $15.00, under dash harness looks good so far, but I dont have it all the way out yet.
leddzepp, The rear harness is cut and spliced and pretty ugly, sorry.
c1069, working on the shipping, it's not looking good, I may not be able to get it done, but I have been working on it.
crig39, The trans lines, I thought were cut up are not. If you are still interested in them all and don't mind a few shipping bends then, $38.00 shipped for all
hotfun, Mark hopefully I will have these off tomorrow. I looked at the bed panel and found one ding only
makamer, The jack and handle are there no lug wrench. $40.00 shipped
Roughedup, a/c panel is not out yet, later tonight and I'll post pics
davedr, I have posted pics of the passenger fender, if you were refering to the inner fender it was no good. Let me know
67chevy1series, I will have the ebrake stuff together and pics later tonight. I want to make sure you get what you need
1967BBC10, column is out, $80.00 shipped without the steering wheel. If you need the wheel let me know, and I'll adjust
Old 01-05-2011, 08:32 PM   #54
sjarrett71
sjarrett71's Avatar
Ok sounds good. I'll commit to the radio and wait until you have the harness all the way out to see what it looks like. It will include the neutral safety switch wiring right? If it's ok with you I'll wait to send payment until we decide if it's any good so I take care of it all at once.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 01-05-2011, 08:34 PM   #55
lynnfield
The Waco Kid
lynnfield's Avatar
clos69, I still have you second on the wheels, I'll know more tomorrow
wideside, wire looms are gone, heatshields depends on condition. I'll know more when the motor sells. (I have a guy local comming to look at it)
mcbassin, so far the under hood harness looks good, I'll know more later. dash harness depends on if the other guy/s pass. I'll let you know
dozerman, I got you in line
burb71, I'll check the bracket, and let you know if the tubs get to you. It's not a sport bumper
astevens, I have posted pics, but don't have it removed yet. I'd like to make sure of the condition, I'll be working on it tonight
1956 cameo, I'll post pics and prices for the items you asked about
I'm not caught up yet, still going to do some more tonight. Hopefully I didn't step over or skip anyone. Thanks Greg
Old 01-05-2011, 08:44 PM   #56
astevens
astevens's Avatar
Ok. I appreciate it. Thanks
Aaron
astevens is offline   Reply With Quote
Old 01-05-2011, 09:18 PM   #57
crig39
how much for e-brake pedal assembly?
crig39 is offline   Reply With Quote
Old 01-06-2011, 01:32 AM   #58
lynnfield
The Waco Kid
lynnfield's Avatar
Late night
Old 01-06-2011, 01:36 AM   #59
lynnfield
The Waco Kid
lynnfield's Avatar
More pics
Old 01-06-2011, 01:38 AM   #60
lynnfield
The Waco Kid
lynnfield's Avatar
Still more
Old 01-06-2011, 01:52 AM   #61
67chevy1series
67chevy1series's Avatar
wel i wont be needing the cable i will only need the two hooks and the e brake equalizer bracket and one e brake cable connector
67chevy1series is offline   Reply With Quote
Old 01-06-2011, 02:21 AM   #62
lynnfield
The Waco Kid
lynnfield's Avatar
sjarrett71, Radio is out, under dash harness is also out. The harness includes everything, door pin to door pin, dome light to fuse block. There is a small splice in the cig. lighter wire, and a small spot on the ignition plug that looks like it got warm at some point, (see pics) overall in good shape. Radio and dash harness, $80.00 shipped for it all
crig39, Lines and e-brake, $65.00 shipped for all
roughedup, A/c control is out, I have this pigtail for the switch from another truck I will include if you need it
67chevy1series, Is this all the ebrake stuff you need? Let me know, I can get more
Mcbassin, the under hood harness it out. It's in good condition, with some minor issues. There is a hole in the purple ignition wire at the block, someone checking voltage at some point I guess, the left headlamp plastic plug is missing, wires are there and ok, dist. wire has been spliced, temp sender wire missing plug, and I cut the wire at the fast idle solenoid, it was the only way to disconnect. $50.00 shipped
astevens, Outer box in good shape, the metal plate has some rust thru at the bottom. Inner box is in good shape, no issues. S duct is useable, but cracked around screw holes. The plastic diverter duct door is no good, and the metal floor duct is in good shape with no issues. $110.00 shipped
Old 01-06-2011, 02:32 AM   #63
lynnfield
The Waco Kid
lynnfield's Avatar
1967BBC10 has passed on the column, Repeeler you are up.
Old 01-06-2011, 02:38 AM   #64
lynnfield
The Waco Kid
lynnfield's Avatar
1956cameo, I have that stuff, ran out of time. Tomorrow, ok?
burb71, still need to look at that bracket
Blap, I believe I have another air cleaner and spacer, let me find it and post pics.
Thanks to all for being patient with me, I am off tomorrow, so I'll be back at it in the morning. Greg
Old 01-06-2011, 02:41 AM   #65
gastrader35
HOARDING SPECIALIST
gastrader35's Avatar
what about the brake pedal and mounting bracket
NEW PROJECT 67 C/10 SHORT FLEET
gastrader35 is offline   Reply With Quote
Old 01-06-2011, 04:24 AM   #66
leddzepp
Moderator
leddzepp's Avatar
No problem, thanks for checking.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-06-2011, 08:28 AM   #67
1956cameo
1956cameo's Avatar
Thanks! No rush just get to it when you can. I will keep an eye on the thread.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 01-06-2011, 09:49 AM   #68
mcbassin
Still Learning
mcbassin's Avatar
Mcbassin, the under hood harness it out. It's in good condition, with some minor issues. There is a hole in the purple ignition wire at the block, someone checking voltage at some point I guess, the left headlamp plastic plug is missing, wires are there and ok, dist. wire has been spliced, temp sender wire missing plug, and I cut the wire at the fast idle solenoid, it was the only way to disconnect. $50.00 shippedastevens, Outer box in good shape, the metal plate has some rust thru at the bottom. Inner box is in good shape, no issues. S duct is useable, but cracked around screw holes. The plastic diverter duct door is no good, and the metal floor duct is in good shape with no issues. $110.00 shipped
I'm really only interested in the harness if I can get complete inside cab and under hood. Let me know if and when the guys ahead of me pass. and best price shipped together. thanks
Old 01-06-2011, 09:51 AM   #69
xman
how much for all the tailgate parts in post #48 shipped to 60435 bussiness
would you happen to have a tailgate handle w/ screws and the rest of the inner hardware
Dave
xman is offline   Reply With Quote
Old 01-06-2011, 04:15 PM   #70
lynnfield
The Waco Kid
lynnfield's Avatar
1956Cameo, A/c & alt. brackets, points dist, breather, spacer & tube. $80.00 shipped
Burb71, I looked at the bracket, it will go with the complete rear, sorry.
blap, Second breather, spacer and tube. Lid needs to be cleaned and painted the rest is clean. $40.00 shipped
gastrader35, brake pedal and mount, $35.00 shipped
Xman, tailgate trunions and hinges, $35.00 shipped. I don't have the inner hardware right now.
Hotfun, Mark, pics of the wheel tubs. I hope to have the bed apart in a few hours.
c1069, I have tried to get this done, but I'm sorry, I will not be able to ship the wheels.
Old 01-06-2011, 04:30 PM   #71
lynnfield
The Waco Kid
lynnfield's Avatar
clos69, You are up on the wheels and tires.
Old 01-06-2011, 04:39 PM   #72
bean
just out of curiosity what would you want for the bed floor
bean is offline   Reply With Quote
Old 01-06-2011, 04:41 PM   #73
lynnfield
The Waco Kid
lynnfield's Avatar
Headed back out now, if I have missed anyone please let me know. Thanks, Greg
Old 01-06-2011, 04:43 PM   #74
lynnfield
The Waco Kid
lynnfield's Avatar
Bean, I'd take $75.00 for the whole thing or just the rear section, your choice come and get it!
Old 01-06-2011, 06:02 PM   #75
olblue60@aol.com
member
Are the window regulators for sale? Do they operate smoothly? Thanks
John
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
