Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-06-2011, 01:43 PM   #1
86 silverado short
sandblaster
can anyone tell me the best working small sandblaster out there. one that will work on playground sand or cheap sand. i have a small one ( craftsman ) but it will not pick up the pg sand. I also just tried some media blast from hf with no luck.
86 silverado short is offline   Reply With Quote
Old 01-06-2011, 05:57 PM   #2
86 silverado short
Re: sandblaster
just something to blast small parts
Old 01-07-2011, 12:15 AM   #3
red69ss
Burnouts are therapeutic
red69ss's Avatar
Re: sandblaster
I always had to screen playground sand to get it to blast. I use a blaster like the 110 lb blaster they sell at harbor frieght. I found it is best to buy fine grade blasting sand as it is screened and dry and ready to go right out of the bag. It's only about $7 a 100 lb bag here, so its not that much more expensive. which blaster do you have? is it siphon or pressure pot?
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 01-07-2011, 11:47 AM   #4
86 silverado short
Re: sandblaster
it is the siphon craftsman model small portable. not working very well have to get on and off the trigger constantly which is a pain in the finger!!! I have a 5 horse 20 gallon compressor
Old 01-07-2011, 12:21 PM   #5
cdowns
cdowns's Avatar
Re: sandblaster
playground sand is a very poor choice. it is tumbled for smoothness and doesnt cut well in blasting. blasting sand has sharp edges and cuts very good when blasting. plus alot of playground sand has higher moisture content causeing poor blasting performance. then theres the worry of where it is mined and if there is salt content in some playground sand
i've found generally those cheap siphon blasters marginal at best, nothing like a pressurized unit.
water filtration is oof the utmost importance blasting air must b dry
when blasting full skin and eye protection is a must as well as good respirator
Old 01-07-2011, 01:28 PM   #6
86 silverado short
Re: sandblaster
thanks for the info. i think i need a pressurized pot system, off to h/f
Old 01-07-2011, 07:20 PM   #7
red69ss
red69ss's Avatar
Re: sandblaster
sound advice from cdowns, I doubt that you will get satisfactory results with that compressor. blasters are air hogs and mine run my comp. pretty hard and its a 5.5 hp 80 gallon. let us know how it works.
1969 CHEVELLE SS
Old 01-08-2011, 12:35 AM   #8
treveiger
treveiger's Avatar
Re: sandblaster
Ive heard if you take your time and let your compresser build up it does the job just fine but it takes longer of course. I have around the same compresser you have and am looking for a blaster so youll have to let us know how it works!
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
