Old 01-06-2011, 06:32 PM   #1
kelsfine69
18 Till I Die
kelsfine69's Avatar
Post Pics of Trans Cooler Mounting
I plan on installing a new BeCool Rad soon and my old trans cooler is held to the rad with those fancy ties that go thru the core. I would like to see some ideas on how to mount a nice trans cooler to the rad support or even other ideas, thanks
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 01-06-2011, 08:59 PM   #2
bigsnookmaster
bigsnookmaster's Avatar
Re: Post Pics of Trans Cooler Mounting
I have one with the elec fan, and I mounted it up under the core support, laying flat.
bigsnookmaster is offline   Reply With Quote
Old 01-06-2011, 10:02 PM   #3
Ram-Man
Ram-Man's Avatar
Passenger side frame rail
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 01-06-2011, 10:10 PM   #4
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Nice Looking Trans Cooler
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 01-06-2011, 10:18 PM   #5
hayhauler71
hayhauler71's Avatar
Made some aluminum brackets that mount to the core support and the cooler painted black. In the pic it.s the two black brackets on the sides of the hood release and the B@M cooler I used. The cooler had holes for very easy mounting.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 01-07-2011, 12:14 AM   #6
big_al_71
big_al_71's Avatar
mine is bolted to the radiator suport see pict below..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-07-2011, 10:58 AM   #7
kelsfine69
18 Till I Die
kelsfine69's Avatar
Big al Does it vibrate?
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 01-07-2011, 01:42 PM   #8
Beelzeburb
Devil's in the Details
Beelzeburb's Avatar
This is the cooler for the 4L80E on my Suburban:
The one on the left is the tranny cooler. I wanted to secure it solidly, because it's a big sucker. It is mounted directly to the grille support / hood release on the right hand side, and on the left it is mounted to a bracket I made from their supplied angle steel in the kit. That bracket is bolted right to the core support through factory holes. The only ones I had to drill were the two small ones though the grille support brace.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread
Datsun 240Z, 510 2 door and an old Honda motorcycle
Beelzeburb is offline   Reply With Quote
Old 01-07-2011, 01:44 PM   #9
big_al_71
big_al_71's Avatar
It is solid and there is zero movement on it. My motor has a big cam so the truck moves alot while at idle and it has been there for two years and zero issues..
Old 01-07-2011, 03:42 PM   #10
kelsfine69
18 Till I Die
kelsfine69's Avatar
How well does this work?
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 01-07-2011, 04:24 PM   #11
72MARIO
72MARIO's Avatar
If you are still in the build stage i welded in 2 flat bars vertically then bolted the cooler to them.
I really like the finned frame mounted coolers.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-07-2011, 05:51 PM   #12
69C-owner
How well does this work compared to the big flat ones the are monuted up front, I like to get one so I can fill in the holes in my core support that the lines are runnin through
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet
1994 Buick Roadmaster
1994 GMC Sonoma
69C-owner is offline   Reply With Quote
Old 01-12-2011, 11:49 AM   #13
kelsfine69
18 Till I Die
kelsfine69's Avatar
Anyone else...
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
