Old 01-07-2011, 12:34 AM   #1
1979Cheyenne
454 Engine I.D. Question
To see the engine I.D. number on a 454 do you have to remove anything? Or is the number clearly visible?
1979Cheyenne is offline   Reply With Quote
Old 01-07-2011, 08:18 AM   #2
b454rat
Re: 454 Engine I.D. Question
if it's in the truck it will be a pain, it's behind the driver side valve cover. Might be able to stick your head close enough to read it, get a pen light or maybe a mirror...
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 01-07-2011, 01:47 PM   #3
1979Cheyenne
The engine is inside the truck. So the valve cover has to be removed for me to see the i.d. number?
Old 01-07-2011, 01:49 PM   #4
BigBlocksRule
Head casting numbers are under the valve cover. Block casting is on the ledge on the back of the block where it bolts to the tranny, driver's side. It'll be facing mostly up, if it's clean you might be able to read it with a mirror. The last 3 digits is probably enough...
BigBlocksRule is offline   Reply With Quote
Old 01-07-2011, 02:06 PM   #5
70BLAZERX2
The suffix code is on the passenger side ,front of block..on the pass. side head mounting surface..Get the code..and i will look it up for you..
a few #s and then 2 or 3 letters are there.
http://www.nastyz28.com/chevy-engine-code-stampings.php
70BLAZERX2 is offline   Reply With Quote
454, engine number
