Old 01-07-2011, 07:47 PM   #1
gopokes
gopokes's Avatar
Removed clutch pedal, is brake pedal strong enough?
I'm swapping from a 3 speed to an auto, so I am taking out my clutch pedal. Does the brake pedal mount need be reinforced since I am taking the shaft out that runs through it's mounting point? The pic below helps for reference. Since I am removing #5 is there still enough structural integrity for the brake pedal to function properly.
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224
gopokes is offline   Reply With Quote
Old 01-07-2011, 08:34 PM   #2
bigsnookmaster
bigsnookmaster's Avatar
Re: Removed clutch pedal, is brake pedal strong enough?
You'll be fine!
bigsnookmaster is offline   Reply With Quote
Old 01-07-2011, 09:53 PM   #3
hayhauler71
hayhauler71's Avatar
Mine has been that way for 8 years now and all is well.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 01-07-2011, 09:57 PM   #4
jaros44sr
jaros44sr's Avatar
Thanks for asking the question, did the same thing as you, and have been wondering awhile. Now I can sleep at night
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-07-2011, 10:26 PM   #5
67chevy1series
67chevy1series's Avatar
if you have that bad of a problemo then get an auto set up from a auto truck
67chevy1series is offline   Reply With Quote
Old 01-08-2011, 12:57 AM   #6
71 super
71 super's Avatar
The pedal sets are the same. An auto set will have the provision to add a clutch pedal, it will not be a problem to have the clutch rod or pedal removed. The seperate setups did not start until 73 or so- auto trucks in those years have a wider brake pedal. In these trucks they were all the same and built on the same base. Hope this helps.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 01-08-2011, 01:09 AM   #7
jaros44sr
jaros44sr's Avatar
Dam, this forum is worth the 25 bucks to get answers like that
SAFETY FIRST
AS usual, off topic
Jim
Old 01-08-2011, 04:00 AM   #8
67chevy1series
hell ya it is!
Old 01-08-2011, 07:39 AM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Everyone listen to this guy.
Auto and standard trucks used the exact same parts. The standards simply got a clutch pedal inserted through the existing place in the assembly.
I see guys selling "auto trans" pedal assemblies for elevated prices sometimes. It makes me want to go pull about a dozen pedal assemblies, pop the clutch pedal out of them and market them as "automatic" units to make some cash.
Like he said, 73 began the different setups with the wider brake pedal on auto trucks.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-08-2011, 11:42 AM   #10
Shyguy
Junior Member
Shyguy's Avatar
This site is great, I learn something new everyday. I will have to tell my son, the mechanic, because he thought there was a difference.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 01-08-2011, 11:33 PM   #11
gopokes
gopokes's Avatar
Thanks for all the help guys! I thought I would be fine, but I vaguely remembered a thread about this same topic and people saying it needed reinforcement. I couldnt find it in a search though. Thanks again for the help!
