Old 01-07-2011, 07:56 PM   #1
71red
71red's Avatar
`71 leaf lowering.... HELP!
Much needed help. I have a 1971 GMC 1500 2 wheel drive with leaf rear. I want to drop the truck 4.5/6 (front/rear) or somewhere really close. I fully expect to c-notch the rear and I have the spindles and springs for the front.
My problem is that I can`t seem to find anywhere (in the forums and online) any flip kits for this year. I even visited a couple of offroad/specialty shops and they tell me this is going to be a custom setup and most likely going to have to chop up my bed. I did find 1 brief write up on a DIY flip with home made saddles. Is this the only way for me to go? And is it safe?
Thanks for any and all input in advance!
Now let`s git this thing in the grass!!!
71red is offline   Reply With Quote
Old 01-07-2011, 10:28 PM   #2
bedsled71
bedsled71's Avatar
Re: `71 leaf lowering.... HELP!
if you can weld.. then buy some spring saddles. set it up, set your pinion angle and burn them in... if you do the other styles make sure the ends fit right up into the bottom of the stock saddles... the alignment hole for the center spring bolt needs to be off center for this application too
bedsled71 is offline   Reply With Quote
Old 01-08-2011, 12:00 AM   #3
butternut1972
butternut1972's Avatar
Have you checked bell tech? I have one in my truck and it works good.
butternut1972 is offline   Reply With Quote
Old 01-08-2011, 02:20 AM   #4
5150.4.67
I did just that. Welded on new saddles with dropped spring shackles from ECE. Done-ski.....
Oh, I think DJM Suspension might have flip kits.......
5150.4.67 is offline   Reply With Quote
Old 01-08-2011, 02:52 AM   #5
5150.4.67
Yup, DJM has em. Part# FK1012
Old 01-08-2011, 01:58 PM   #6
SCOTI
SCOTI's Avatar
A true 67-72 kit would be the easist 'no modification' approach. A 73-87 kit would prob work w/some slight grinding on the 'U'/flip saddles so they fit within the OE leaf mounts (IIRC, the 71-72 leafs were 2.25" w, the 73-87's are 2.5" w).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-08-2011, 02:19 PM   #7
71red
71red's Avatar
AWESOME! thanks for the feed back! I will check into these options. As far as pinion angle. what should that be?
Old 01-08-2011, 02:21 PM   #8
71red
71red's Avatar
What do you mean about "ends fitting up" ?
BTW Found that DJM kit for 70-72 @ http://djmfactorystore.com/shop/arti...%3DFK1012-5%26
Thanks 5150.4.67!!!
Old 01-08-2011, 04:00 PM   #9
SCOTI
SCOTI's Avatar
He's prob referring to the slight grinding I mentioned....
Differnt trucks w/different ride height need different pinion angles. From what I've researched while trying to set mine up, you want about 1° difference between opposing angles on the trans tailshaft & the pinion yoke (trans -3; pinion +2).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-08-2011, 04:16 PM   #10
5150.4.67
The angle between the engine and rear end should be the same (and opposite) for general purposes.
For instance 3 degrees between trans and driveshaft, and -3 degrees between driveshaft and rear end at ride height. Use shims to alter angle.
Make sure they are 2.25 in's wide, not 2.5.
CPP should have shims, maybe even Summit.
You will need an angle finder as well.
Jay
Old 01-08-2011, 04:23 PM   #11
5150.4.67
Lots of good info on this site as well.....
Old 01-09-2011, 03:12 AM   #12
71red
71red's Avatar
Right on! thanks again. You all have saved me big time! Just ordered the flipkit today.
