Old 01-08-2011, 04:33 PM   #26
irish1966
irish1966's Avatar
Re: To Serp or not to Serp???
Originally Posted by vin63 View Post
The main benefit of a serpentine system is that it is able to run many accessories at a lower tension, which takes less horsepower to drive. Also, it is more stable for accessories that are mounted further away from the crank pulley. If you can make a late model system work, that would be great. As the others mentioned, be sure to grab all of the hardware and fasteners. Sounds like a great deal...and your idea of mocking it up on a spare engine is perfect. post some photos.
Here's a photo of my March system I cobbled together and modified to fit on my Pontiac...it was free, but it took a lot of effort and machining to work.
Went and grabbed the stuff from the junkyard this morning. The guys pulled everything off the front of the motor except the a/c compressor. I got the a/c delete from autozone last night, so hopefully this weekend I'll have some pics on here of how I get it all together and any issues I run into.
Cheers
David
66 LWB Fleet (on hold)
64 LWB Fleet (daily driver)
65 SWB Fleet (almost finished as a driver)
64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck)
Nothing worth doing, is easy.
irish1966 is offline   Reply With Quote
Old 01-08-2011, 05:10 PM   #27
irish1966
irish1966's Avatar
I had to go back to work after my spin to the junkyard this morning, but I am itching to see how this sys will go together on the block at home. I did notice that all of the bolts etc on the s-10 were Metric, so it should be fun when and if I have to take stuff off the motor. Luckily I am european and normal numbers (metric) are what I am used to. I'll never forget being asked to machine something to x thousands of an inch. SAY WHAT????? Lol
The micrometer scale was tricky enough to work with.
Anyways, back to the job at hand......
Any tips on the alt setup? I haven't got to look at the wire setup but I asked the guys to cut off the pigtail when they took off the alt.
Cheers
David
Old 01-15-2011, 11:32 PM   #28
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Well, lets see the new setup....
screamin_c10 is offline   Reply With Quote
