Old 01-09-2011, 11:19 PM   #1
FLcustom10
Return Fuel Line?
Do I need a return fuel line? I'm ordering new fuel lines and am confused on whether I need the return line or not. The truck is torn down to the frame and I'm not sure I remember what all I removed... I remember taking off the fuel line and the vapor line, but I don't remember a return line. It's a 1972 C10 with a 307 v8.
Also - I'm going with 3/8" fuel line. I'm not sure if it was 5/16 or 3/8 before. Are there any concerns in case it was 5/16 before?
FLcustom10 is offline   Reply With Quote
Old 01-09-2011, 11:25 PM   #2
butters_72
butters_72's Avatar
Re: Return Fuel Line?
my 1972 c10 350 has the tank behind the seat and the two on the sides of the bed and it has a return line that runs to the maintank behind the seat and im running 3/8 hoses, you can always just look at your fuel pump, if it just has two fittings then theres no return if it has three then on of which is the return hope that helps
[B][COLOR="Navy"]BUTTERS
72 Chevy longbed C-10
72 Chevy 4x4 Longbed
butters_72 is offline   Reply With Quote
Old 01-09-2011, 11:34 PM   #3
chewychevy67
67 was the last year for 5/16 in the trucks. 68 used 3/8 because of the introduction of the big block i believe.
chewychevy67 is offline   Reply With Quote
Old 01-09-2011, 11:37 PM   #4
FLcustom10
Good answer! I just checked the fuel pump and it only has 2 fittings so no return line. Thank you.
Old 01-09-2011, 11:39 PM   #5
butters_72
butters_72's Avatar
no problem glad i could help good luck with your rebuild
Old 01-09-2011, 11:54 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
inlines, and 2 bbl trucks used 5/16ths line through 72. All big block, 4 bbl small block, and all V6 engines used the larget 3/8ths line
Old 01-25-2011, 09:39 PM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I asked this in another thread, but I think this thread may be more on topic.
Is there a benefit in running a return line?
Most all newer chevys have the 3 port fuel pump.
If we don't have a return line, is it a big deal?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
