01-10-2011, 01:00 AM | #1 |
Fender and grill alignment
Pic says it all. Problem is in the red circle. How can I fix this?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
01-10-2011, 02:50 AM | #2 |
Re: Fender and grill alignment
can you take a more straight on picture, and are all the pieces original or aftermarket?
[B][COLOR="Navy"]BUTTERS 72 Chevy longbed C-10 72 Chevy 4x4 Longbed |
01-10-2011, 01:22 PM | #3 |
Can you open up the holes some on the grill where it mounts to the fender and twist it up then tighten it down. It looks like it should line up. You could leave that side unbolted tighten the other 3 corners and see if you can twist it to line it up.
Posted via Mobile Device |
01-10-2011, 03:12 PM | #4 | |
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 Last edited by skokie; 01-10-2011 at 03:13 PM. |
01-10-2011, 07:30 PM | #5 |
i agree with ram-man, can you hollow out the holes a little bit so you can give it a little twist? do all your other pannels line up properly?
01-10-2011, 09:28 PM | #6 |
Yep will do and I just remembered that the drivers fender is not original. I had to replace it.
01-10-2011, 10:00 PM | #7 |
Ive wrecked my truck twice now and so Ive changed the front ends twice aslo. meaning front fenders, inner fenders, hood, bumper, radiator support and grill. And both times I replaced them with after market fenders but the grills were original and I had this happen both times on one side. I had to adjust my fenders several times tighting them and untighting them. It was really a pain. Eventually I got the grill to line up. but ram-man's Idea should work.
1970 chevy c10 350 |
01-10-2011, 10:43 PM | #8 |
Try and elongate the holes in the bracket on the grille (to pull it up) yes after market fenders are that much off! should be very easy to bring everything into line . give it a try! I know you can do it! cheers, Pat
01-10-2011, 10:56 PM | #9 |
yep same problem with mine on the pass side. After market fenders for you. I was thinking about elongating the holes on the grill also but noticed that the grill is actually hittting the to of the fender . Really weird setup but maybe I will fix it when I get a new grill.Good luck and let us know how it turned out
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. |
