Old 01-10-2011, 02:46 PM   #1
codydubb
codydubb's Avatar
400 sbc price
just curious on opinions i have a chance to pick up a 400 but curious what everyone thinks its worth, its been bored .030 over at one time but it needs a total rebuild right now and its a 2 bolt main.
1985 Chevy C10
350 .60 over iron eagle h-beam rods, sealed power high comp pistons, forged crank, vortec heads, edelbrock performer rpm vortec intake, roller rockers, .488 .510 cam 750 Demon Double Pumper, Longtube headers, Dual Flowmaster exhaust,Dual electric fans, Proform electric water pump. TCI 3500 Stall Converter th350 trans B&M shift kit 10 bolt 3.73 Detroit Locker
codydubb is offline   Reply With Quote
Old 01-10-2011, 04:12 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: 400 sbc price
From what I hear, 30 over is maxxed out for a 400. If it's ready for a rebuild again, there may not be enough meat left on the bone.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 01-10-2011, 04:27 PM   #3
spudz
spudz's Avatar
Re: 400 sbc price
I would also be scared of a bored 400. I would want to have it sonic checked to see if it can be bored again.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 01-10-2011, 04:59 PM   #4
codydubb
codydubb's Avatar
Re: 400 sbc price
ok. and another question ive read any 400 pushing over 400 needs splayed main caps?
1985 Chevy C10
Old 01-10-2011, 05:58 PM   #5
BigBlocksRule
Re: 400 sbc price
2-bolt 400's are stronger than 4-bolt blocks. The outer bolts cut through the weakest part of the main web. If it was run at .030, see if it'll clean up at .040 with a good hone job. If it has a ridge around the top of the bores, it probably won't clean up that way and is not a good candidate. Thin cylinder walls plus thin fire ring on head gaskets really restricts how much overbore you can get away with.
I've seen several 2-bolt main 400's at 500 - 550hp, but I sure wouldn't want to push it fartherr than that.
BigBlocksRule is offline   Reply With Quote
Old 01-10-2011, 07:11 PM   #6
mooseknuckles
mooseknuckles's Avatar
Re: 400 sbc price
my buddy had a 406, 2bolt mains, water jackets half filled with this block cement stuff for added strength, made over 500 hp and 480 tq. that thing was crazy.
mooseknuckles is offline   Reply With Quote
Old 01-10-2011, 07:43 PM   #7
3r!c84
Badass
3r!c84's Avatar
Re: 400 sbc price
wrong. 2 bolt mains are stronger then the 4bolt 400s. but in that power range. you dont need splayed caps. go check out my thread i just built a 400 for my truck. getting me into the 13s in the 1/4. upwords in the 400hp range.
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-11-2011, 12:38 AM   #8
slugish
Slugish
Re: 400 sbc price
Yea, mine is bored .40 over with concrete & HAVE RUN THE DOG**** OUT OF IT FOR 7 YEARS.
slugish is offline   Reply With Quote
Old 01-11-2011, 12:50 AM   #9
3r!c84
Badass
3r!c84's Avatar
Re: 400 sbc price
Whats this talk about concrete? How do it stay cool?
-00 Saturn 5spd
1/4:13:90
Old 01-11-2011, 01:21 AM   #10
mongoose
mongoose's Avatar
Re: 400 sbc price
but running it for a minute at a time... there's still cooling depending on how much you actually fill it.. it's more or less a drag only type of a mod.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 01-11-2011, 11:03 PM   #11
slugish
Slugish
Re: 400 sbc price
old gear head built my engine . Had some world class small blocks back in his day . The correct amount of concrete is essential (don't know what that is ) but I never overheat > run a 160 thermostat > most it gets is 180-190 when it's hot outside .
Old 01-11-2011, 11:10 PM   #12
3r!c84
Badass
3r!c84's Avatar
Re: 400 sbc price
how do coolant flow then?
-00 Saturn 5spd
1/4:13:90
Old 01-12-2011, 03:45 AM   #13
Hazieview
Building Dreams out of Dimes!
Re: 400 sbc price
I dont really know how much one would be worth but I do own one. I own a small block 400 bored .030 over. It is a torque monster!
If you want the block tell the person you are buying it from that you want to have it checked out.
If he is honest he should have no problem. Take it to the machine shop. Let them look it over. If it is good give him the cash. If not I doubt he will want it back unless he sells scrap metal...
Just my 2 cents... It has worked for me in the past! Good luck!
Hazieview is offline   Reply With Quote
Old 01-12-2011, 08:08 AM   #14
BigBlocksRule
Re: 400 sbc price
Most that use hardblock just fill 'em to the water pump holes. They can actually run on the street when filled, the bottom part of the bore doesn't get nearly as hot as the top, so they make sure to leave the top of the block's cooling jackets open for coolant flow.
That said, I wouldn't mess with trying to run a filled 400 on the street, with no coolant flow between the tops of the cylinders, I'd bet it'll overheat and maybe crack.
Old 01-12-2011, 09:36 AM   #15
spudz
spudz's Avatar
Re: 400 sbc price
I would say its worth no more then 100 bux.... atleast to me it isnt..
