Old 01-10-2011, 09:43 PM   #1
X Baldwin Motion
X Baldwin Motion's Avatar
84 Wiper switch and Washer res bracket
back to the 84 Silverado. I have the intermittent wiper switch (with cruise control) and at this stage of it's life it pretty much does what it wants, when it wants to. The only function that is dependable is the high speed, even that when shutting it off you have to be talented to park the wipers low. So, can I assume that since the motor performs well at high speed, that it is the switch that should be replaced?
One other thing, I am missing all the washer components and see that it is all available after-market except the bracket that holds the washer fluid reservoir to the fender wall, any leads on where I can obtain this bracket ?
any and all suggestions welcome and as always, Thanks in advance for the help.
1985 Custom Deluxe long bed 305 3 on tree
2015 Silverado "Great White"1987 K20 dump and plow
1968 K20 327 long bed 4spd big blue
68K20 SuburPan 4spd
79C30 L96 6L90e
86 K10 plow
X Baldwin Motion is offline   Reply With Quote
Old 01-20-2011, 07:30 PM   #2
X Baldwin Motion
Re: 84 Wiper switch and Washer res bracket
anyone? anything?
anywhere to find the bracket that holds the washer fluid res ?
thanks
68K20 SuburPan 4spd
79C30 L96 6L90e
86 K10 plow
Old 01-21-2011, 02:03 PM   #3
hatzie
Moderator
hatzie's Avatar
Pick N Pull for the bracket.
Self parking is controlled by a cam switch on the motor that interrupts the motor ground.
The parking switch and cam are inside the linkage gearbox. My best guess is the gearbox was disassembled in an attempt to repair the OEM washer pump... The wiper switch may be OK.
Old 01-28-2011, 04:07 PM   #4
X Baldwin Motion
Is it best then to get the entire pump/motor assembly and hope the switch is good? thanks for the help.
68K20 SuburPan 4spd
79C30 L96 6L90e
86 K10 plow
Old 01-30-2011, 11:55 AM   #5
hatzie
Moderator
hatzie's Avatar
If someone disassembled the motor gearbox it's probably missing pieces but only if it's been disassembled. If you're positive the motor has never been disassembled then it's the column switch.
If the motor pedigree is questionable do some detective work It could be either.
Pull the column switch plug off the pulse controller under the column and check the switch states against this diagram.
Old 02-05-2011, 01:32 PM   #6
X Baldwin Motion
"check the switch states against this diagram"
I may need a little more info to perform the test you suggest...not really sure what you mean.. thanks.
I should mention that the "parking" of the wipers sometimes works, and sometimes not. Same goes for the low speed, sometimes they move in a stuttering jerky motion and sometimes they just stall completely mid cycle.
68K20 SuburPan 4spd
79C30 L96 6L90e
86 K10 plow
