Old 01-11-2011, 08:31 PM   #1
jakeblues652
jakeblues652's Avatar
'68 cab on a '67?
is this possible from the factory, if it got late in the '67 year, because as far as i know, the cab is original, and the VIN says its a '68 and the title says its a '67.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 01-11-2011, 08:37 PM   #2
67chevy1series
67chevy1series's Avatar
Re: '68 cab on a '67?
well jake when i look at a truck from a far and it looks like a 67 heres what i look for to tell me what it is
the fire wall
dash
fenders from the inside to see if i can see body work where the marker lights are
and trim holes
the rear window
when i see a truck like yours i seen that it had 68 fenders and 68 cab that told me it was a 68
67chevy1series is offline   Reply With Quote
Old 01-11-2011, 10:40 PM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
Jake...a couple things to add to what Rick said above...try to find the partial VIN number stamped on the top frame rail driver side...could be just in front of the cab mount or out towards the engine...and see if it matches the VIN on the SPID and driver side door pillar..
other things...does the cab have a big back window (it was an option only in 67, std in 68), side markers on the fenders and bed
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-11-2011, 10:46 PM   #4
jakeblues652
big window. and the P.O told me that they changed the bed and the front fenders out with a '68 just because they liked the look of the lights.
Old 01-11-2011, 11:29 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if the VIN plate is original, then why are you questioning it? That is the trucks's identity.
Are you willing to post the VIN for us to decode?
Old 01-11-2011, 11:35 PM   #6
jakeblues652
i decoded it earlier. everything is right except the year on it. im just curious to why the vin says 68 and the titale says 67. maybe its some stupid thing that was done wrong back then, but we may never know, right?
and if it matters, the cab DOES NOT have the small key hole.
Old 01-11-2011, 11:43 PM   #7
Longhorn Man
thn it's a 68.. right? Whats the last 6 on the VIN? I could see if it is a 100200 then it would have been built and even sold in early 67, and a dumb @ss dealer/DMV worker could have done it up wrong and it stuck... or maybe it was from a state where titles weren't needed after 10 years or whatever, and going by some old guy's memory...
but what the VIN says, assuming the VIN is real and not scabbed in by some PO,but the vin is the ID.
Old 01-12-2011, 09:34 AM   #8
Does it have a '67 dash? It probably doesn't. It sounds like it's a '68 that's incorrectly titled as a '67. Or,it has had some swapping around. Do the numbers on the frame match the body and does the frame have a dimple behind the steering box? Does it have power steering??
Old 01-12-2011, 11:15 AM   #9
jakeblues652
power steering, yes. dimple..not sure?
Old 01-12-2011, 12:08 PM   #10
Stubbs67
Stubbs67's Avatar
I think its a screw up on the part of the dmv. My 68 that i had 7 years ago was the same way, the title said 67 but it was definately a 68. fenders, dash, markers, big window. no doubt and it was a survivor, and an extremely awful lime/babydookie green. every part, inside cab, fenders, bed and all. We named it trugly.
67 Short Step Project -My other wife, ya know... (she takes all my time and money and I don't even realize it)
88 Subaru wagon 4wd -Daily driver and workhorse
98 Subaru Forester S - Wife and baby wheels
My Build Thread!
http://67-72chevytrucks.com/vboard/s...d.php?t=433751
Need step tail gate and bed front, driver door, both front fenders (both are bondo'd nightmares). can trade fleetside bed parts real straight (except sides) or pay some cash (i am pretty broke)
Stubbs67 is offline   Reply With Quote
Old 01-12-2011, 12:16 PM   #11
too much stuff
Roadtrip!
too much stuff's Avatar
Sounds like a 68 to me. I can't imagine someone changing the box and fenders to have side markers. Usually people are filling them in. I would double check all your numbers. VIN, glovebox, frame and title. The dimple would be where the steering box is bolted to the frame. Is it flat?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-12-2011, 12:35 PM   #12
And a '67,originally,would have a ram-assist type of power steering...nothing like '68-up. does this truck have the SPID?
Old 01-12-2011, 01:06 PM   #13
maynardtruckin
maynardtruckin's Avatar
just from your video your truck is a 68 looking at the ignition switch hole. 67 had a smaller bezel and therefor a smaller hole. Also if it has a pedal for the e brake it would be a 68, 67 used a pull handle mounted under the steering column.
Chris
67 c10 swb build in progress
70 c10 lwb driver pending parts for drastic overhaul
70 c20 lwb parts truck for above mentioned drastic overhaul
71 k20 lwb building for off road use and towing
maynardtruckin is offline   Reply With Quote
Old 01-12-2011, 01:10 PM   #14
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey maynardtruckin....FYI....69-72 uses the foot ebrake....68 has the hand operated ebrake...
Geoff with a G
Old 01-12-2011, 01:43 PM   #15
maynardtruckin
yes early 68 had pull handles but mid to late 68 had pedals according to the facterey build sheets and specs I saw from the Kansas City MO plant.
Chris
Old 01-12-2011, 01:47 PM   #16
too much stuff
Roadtrip!
Every 67 and 68 i have seen has the hand brake. 69 and up got the foot brake.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 01-12-2011, 01:53 PM   #17
gcburdic
Restoration Virgin!
gcburdic's Avatar
This is good to know....I'd love to see one from the factory like that...defintely be a rare bird....Thanks for the info
Geoff with a G
Old 01-12-2011, 01:53 PM   #18
teeitup
Just like to part out trucks!!
teeitup's Avatar
I think you have a body swap truck. What letter does the vin plate start with? If its a C your truck has a 2wd body on a 4x4 frame
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 01-12-2011, 02:02 PM   #19
jablack
Classic Chevy Recycler
jablack's Avatar
My 67 has the dimple behind the steering gear box, but it was a c20. It had power steering too but that could have been put on by a po.
2004 Chevrolet Trailblazer EXT
1970 Chevrolet C50
1979 Chevrolet C30
Need another 67 or 68 soon...
jablack is offline   Reply With Quote
Old 01-12-2011, 02:59 PM   #20
I didn't know it was a 4wd we were talking about. This could explain something.
Old 01-12-2011, 04:57 PM   #21
teeitup
teeitup's Avatar
I was looking at his Youtube video Tim, thats the only reason I thought of that. Also he said in video reverse was to you and up it should to you and down, atleast my 67 with a sm420 is
1980 chevy swb 4x4
Old 01-12-2011, 05:26 PM   #22
jakeblues652
it is 4 wheel drive, and the VIN agrees, and the spid is long gone. it has sm420. hand brake type e-brake. will check on the dimples and such when the weather gets a little nicer. we got about 8 inches of powder last night.
Old 01-12-2011, 06:03 PM   #23
Longhorn Man
that was probably late 68 when they were tooling up for 69s.
Old 01-12-2011, 06:25 PM   #24
Yeah,must be rare. I have never seen a '68 with a foot brake.
Old 01-12-2011, 08:46 PM   #25
maynardtruckin
Well the 68 sub I had had one and I have personaly seen six more trucks with them that a buddy has bought and sold over the years. I know my 67 swb is a pull handle and i have seen early 68's with pull handles. My 69 4x4 is pedal both my 70 and the 72 are all pedals. but the truck in question is a 68from all i have seen probably retitled due to no title or something like that!
Chris
