18 Till I Die
Post Pics of Trans Cooler Mounting
I plan on installing a new BeCool Rad soon and my old trans cooler is held to the rad with those fancy ties that go thru the core. I would like to see some ideas on how to mount a nice trans cooler to the rad support or even other ideas, thanks
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
![]() Join Date: Jan 2008
Re: Post Pics of Trans Cooler Mounting
I have one with the elec fan, and I mounted it up under the core support, laying flat.
Passenger side frame rail
Retired Air Force Veteran
![]() Join Date: Aug 2007
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
Made some aluminum brackets that mount to the core support and the cooler painted black. In the pic it.s the two black brackets on the sides of the hood release and the B@M cooler I used. The cooler had holes for very easy mounting.
Fuzzy |
mine is bolted to the radiator suport see pict below..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
18 Till I Die
Big al Does it vibrate?
Devil's in the Details
This is the cooler for the 4L80E on my Suburban:
![]() The one on the left is the tranny cooler. I wanted to secure it solidly, because it's a big sucker. It is mounted directly to the grille support / hood release on the right hand side, and on the left it is mounted to a bracket I made from their supplied angle steel in the kit. That bracket is bolted right to the core support through factory holes. The only ones I had to drill were the two small ones though the grille support brace.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
It is solid and there is zero movement on it. My motor has a big cam so the truck moves alot while at idle and it has been there for two years and zero issues..
18 Till I Die
If you are still in the build stage i welded in 2 flat bars vertically then bolted the cooler to them.
I really like the finned frame mounted coolers.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 01-07-2011 at 04:26 PM. |
How well does this work compared to the big flat ones the are monuted up front, I like to get one so I can fill in the holes in my core support that the lines are runnin through
http://67-72chevytrucks.com/vboard/s...d.php?t=438550 ![]() ![]() 1994 Buick Roadmaster 1994 GMC Sonoma |
18 Till I Die
Anyone else...
