01-13-2011, 10:25 AM | #301 |
Lucky Teter at the wheel
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
I got on another thread yesterday that was discussing how bad it was to notch your frame from a strength standpoint. I posed a question about my hot rod pickup bed situation and one of the guys who was an engineer had a better solution and did a cad drawing of it. It involves a fair bit of work, but totally solves my frame kick up problem without having to cut on the frame any. Brilliant, thanks a lot John (Lakeroadster). I will be taking his idea and running with it soon.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
01-13-2011, 01:46 PM | #302 | |
I know for a fact I have the first 72 CREW CAB with a late model Hydro-formed frame!
01-13-2011, 02:28 PM | #303 | |
Still plays with trucks
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
01-13-2011, 02:39 PM | #304 |
67cheby
you can always just raise your bed floor the way i did mine and it keeps it pretty stock looking
01-13-2011, 02:45 PM | #305 | |
Here is the link to the other thread. http://67-72chevytrucks.com/vboard/s...=393867&page=5
01-13-2011, 02:53 PM | #306 |
67cheby
yes... that indeed does look like a great plan with lots less work, i think you have a winner !!
01-13-2011, 10:00 PM | #307 |
I cannot beleve he didn't put some kinda reserve on it! Musta been really hurtin for cash.. Good score! I'd give up all 3 of my rollaways and top chests for that.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
01-13-2011, 10:31 PM | #308 |
6>8 Plugless........
Nice progress on the frame! That is a great solution! Too bad he quit giving advice, he knows his stuff.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 01-13-2011 at 10:42 PM. |
01-14-2011, 12:24 AM | #309 |
I really like the newer frame, I have wanted to do this for some time now. My last work truck was a 2000 3/4T chevy with a 5.3 and I turned it back into our shop with 265,000 miles after only having to replace 1 fuel pump at 80K and a water pump at 210K. Even the brakes were the originals and I towed allot with that truck and over loaded it on a regular basis. Great platform for a daily driver.
I think I just solved my labor problem! Kevin LFD Inc. |
01-14-2011, 01:53 AM | #310 | |
Still congratulations it is a nice place to store your tools when you have one, sometimes I regret selling mine. Sorry to Highjack, end of tangent.... And you are building an awesome truck |
01-14-2011, 01:58 AM | #311 |
Got bored with cutting and grinding on the frame, plus, Gnande wasn't home to help so I thought I would start to investigate how the steering could be put together. The 2001 rack and pinion has some nice u joints that are required to get the severe angles to work out. I will have to keep that portion of the shaft. The 1972 shaft has some cool internal workings that are required to make the shift lever work and have detents for park, reverse, drive, etc. I'll have to keep that part of the shaft intact too. All of these required parts are about 6 inches too long. Uh-Oh.
01-14-2011, 02:09 AM | #312 |
Well, my investigation turned into full blown how in heck is this going to work/let's just try some stuff. I had really been dreading this and worrying how it would come together, so I just dove in. First thing I noticed that could go was the accordion looking shaft. Choped that off and the remainder slides into the leftover piece. I can now just weld this together and voila (pronounced wah lah) I just saved 5 inches. Next I pulled the shaft to the rag joint and discovered an extra 1.5 inches there by making up a connection sleeve from the leftover rag joint shaft. I cut a little 2 inch section out and drilled 2 bolt holes.
01-14-2011, 02:19 AM | #313 |
I wasn't so lucky that my sleeve just slid over my 2 shafts that I was bringing together, but they were both close. The 2001 end had 2 flat sides already, I just had to grind them down smaller. The old shaft on the 72 had splines and a flat groove on 1 side. I ground down the opposite side and the sleeve now would slide onto both parts. To me this is true Hot Rodding, taking parts from different vehicles and machining them to fit and work together. So much more satisfying to make it myself than buy it and bolt it on (sorry vendors).
01-14-2011, 02:22 AM | #314 |
3 hours after starting my investigation and here we are, finished and ready to bolt in using the factory 72 steering column mounts. Time for bedtime prayers, good night all.
01-14-2011, 04:53 AM | #315 |
Nice job and great innovation. I find myself doing the same type of stuff all the time. I try to use what I have because it is cheaper most times, and I want to get it done.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-14-2011, 09:50 AM | #316 |
I like the idea but here are my $.02 for safety sake. It looks like the 01 end that you had to drill is aluminum and if so they are ok in stock form but now with the hole drilled into it their is very little "meat" left. Also aluminum is a funny metal in that it can be work hardened when used for steering and suspension parts but once you start drilling or grinding on it the heat produced will start to anneal the metal causing it to soften. Not what you want in your steering system.
So what I would do if this is the only way to hook up the steering is to take the other end of that same joint (but off a different shaft) that is metal and press the joints apart. Then re-build them so you end up with 2 steel ends that you can then weld the coupler to and not just rely on a single bolt that can end up wobbling out the hole and cause slop or a failure. I hope this makes sense and I also hope this is coming across as for "safety" and in no way a slam on your design. I will give you a call later about the cover and air box. Kevin LFD Inc. Last edited by Rokcrln; 01-14-2011 at 09:52 AM. |
01-14-2011, 10:38 AM | #317 | |
01-14-2011, 12:21 PM | #318 | |
With your crew cab you could probably make the newer dash & column work by just relocating the front seats rearward a little until you had enough room to be comfortable but I like the idea of keeping the stock 72 interior and column too. I should have done the chassis & drivetrain swap anyway but I gave up on the project when I couldn't make the dash work out. I really wanted the dual zone climate control system, driver information center / gauge cluster and stereo out of the 03.
01-14-2011, 12:23 PM | #319 |
Great information and you are a true HOT RODDER. Keep making it yours by doing what hasn't been done. Very good thread.
01-14-2011, 03:51 PM | #320 |
Cool build. Got to see it done.
Bryan
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350. http://www.facebook.com/#/profile.ph...&id=1116781152 |
01-14-2011, 05:38 PM | #321 |
That is a lot shorter steering shaft with the rack & pinion. I am looking at setting up my suburban on a newer chassis also. Since I don't have any drivetrain yet a complete but wrecked vehicle will be cheaper.
Travis 2005 K2500 Duramax (hauls the junk home) 1967 Chev C10 (hauls a$$) 1970 Suburban (Yukon XL 4 door) 1968 GMC 3/4 ton (sheetmetal only, chassis gone) 2005 Malibu (wife's car, still a Chevy) Project Family Hauler New Home for Chevys (Moved in and working) |
01-14-2011, 05:41 PM | #322 |
I love this build,keep up the good work.
big old burb in primer.lot of work to do. |
01-15-2011, 10:35 AM | #323 | |||||||||||
I'm in the engineering jigsaw puzzle phase!
01-15-2011, 03:07 PM | #324 |
wow about 11 quotes!
01-15-2011, 04:23 PM | #325 |
Here are a few parts coming your way! I made yours out of 18ga then added a few beads into it for looks and rigidity. They will mail out Tuesday.
Kevin LFD Inc. |
