Old 06-28-2003, 04:44 PM   #1
superchevy
Got big-block?
superchevy's Avatar
where can I get the small u-bolts that hold the front lower control arms on?
Was hoping A-zone had them, but they don't.
SC
superchevy is offline   Reply With Quote
Old 06-28-2003, 05:51 PM   #2
knucklebuster
Failure is NOT an option!
knucklebuster's Avatar
I think I've got some extra ones if you need them I'll look
House payment or truck parts?????.........why does life have to be so complicated?
1969 Chevy Shortbed Fleetside
1969 Camaro ps pb a/c(drove in high school now it's just a yard ornament,but it's next on the list for resto)
1990 Ni$$an hardbody( daily beater that has been really beaten!)
1999 Grand Am GT(wifes ride...never buy a pontiac!!Trust Me)
knucklebuster is offline   Reply With Quote
Old 06-28-2003, 07:41 PM   #3
orange71
The chevy dealer still has them for around $10 a piece and you will still have to buy the nuts
orange71 is offline   Reply With Quote
Old 06-28-2003, 10:57 PM   #4
BubbaGreen
Ya...GM has those U-Bolts for sale (at least I got mine from there approx 6months ago).
Just be aware. The ones I took off used a 1/2-20 nut. The new
ones GM gave me used a 9/16 inch nut. I did not realize this until
I test fit them.
I purchased extra thick flat washers from ARP and compression nuts from a local supply shop. The 9/16 U-bolts fit fine thru the cross member, no drilling required. Does make me wonder what is correct.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 06-29-2003, 01:13 AM   #5
Stroker
BubbaGreen I came across the same 1/2 vs 9/16 U bolt issue. The GM parts guy told me the larger u bolt was actually for a later model truck but listed as a sub for our trucks. I don't know if he was BSing me or not. But in the end it worked fine and should be a little stronger.
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 06-29-2003, 02:21 AM   #6
beau396
You can also have a shop that makes leaf springs bend you new ones, or you can do what I did and get them from Wes at classic heartbeat.
'67 C10 short box fleet side wood bed small rear window frame off restoration. 396BB,Th400, ps, pwr disc 5 lug, posi 3.07, 2000 Suburban 60/40 pwr seats, 2.5" front drop 4" rear, powder coated running gear.
beau396 is offline   Reply With Quote
Old 06-29-2003, 10:02 PM   #7
knucklebuster
A friend of mine that owns a front end shop told me to make sure I had the big ones because they have had problems with the smaller ones breaking and that's why they started using the bigger ones.
