Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 01-15-2011, 02:55 PM   #1
Pro Metal Shop
WIW 70 307 3spd complete
Hi Guys
I just need an idea of about how much the entire package would be worth ?
Its a bone stock 307 / 3spd and if I was to sell it I would sell everything from 3 on the tree column that works as , like new. The z bar , mounts and trans mount and everything. Nuts , bolts , grease and grime I meen everything ! ! ! ! even the exhaust that came off it.
Now for some history, the motor ran great did not smoke , started in the worst weather. Trans shifted perfectly, throw out bearing made noise but clutch worked fine.
Air cleaner is 100% complete as are the pully's . I figure if I am going to swap out drive line I am going to swap completely. and rather than store the old I would loosen up some bucks........Thanks in advance guys
Thanks Steve
http://chevylegends.com/forum/index.php
Pro Metal Shop is offline   Reply With Quote
Old 01-16-2011, 09:11 AM   #2
Pro Metal Shop
Re: WIW 70 307 3spd complete
TTT
Thanks Steve
Old 01-16-2011, 11:19 AM   #3
Mt Man Chad
Mt Man Chad's Avatar
$100-$300 my guess, depends who's interested
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 01-16-2011, 11:25 AM   #4
Pro Metal Shop
Hey thanks Chad , I kinda though in the 400 range so I wasn't that far off. My thoughts were the entire motor and it's sheet metal components were all there.
I figured if I could not get enough or close to that I would stick it in a resto rod project .....
Thanks Steve
Old 01-16-2011, 12:09 PM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
$350ish I just sold a complete 250/3 speed for 200 so the V8 should be worth a bit more.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-16-2011, 06:51 PM   #6
Pro Metal Shop
ok so 350ish would be the motor and trans ? how about with column , z bar , and items related.. Thank much for you guys input
Thanks Steve
