01-16-2011, 02:31 AM | #1 |
Truckin' Krazy
Tilt column
RV Tilt
Tilt is tight no damage or pry marks on the tilt head Shifter handle spring is missing Turn signal switch arm bent, another non cruise arm will be included turn signal cam broke Cancel cam & spring included Column same length as a truck Shaft sticks out the bottom same length as a truck Neutral safety switch needs to be relocated if your using it This is a great candidate for someone looking to make a 4 speed tilt column for cheap. $175 shipped Thanks, Tom
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
01-16-2011, 02:47 AM | #2 |
Re: Tilt column
good deal for someone, sure wish i had the money for it
01-16-2011, 03:46 AM | #3 |
Re: Tilt column
Is the pin still tight on the shift lever? How about $150 shipped?
01-16-2011, 03:53 AM | #4 |
Truckin' Krazy
Re: Tilt column
70shortfleet, pin is tight, gonna stay at $175 for now.
Thanks, Tom
01-17-2011, 03:15 AM | #5 |
lovin' the lowcountry
Re: Tilt column
Interested, what would be needed to turn this into a 4speed column?
Chris 29461 72 SWB stepside 71 SWB stepside DRIVE IT LIKE YOU STOLE IT! |
01-17-2011, 03:57 AM | #6 |
Truckin' Krazy
Re: Tilt column
72 shortstep, Pretty much the ability to do a little fab & body work, you just do away with the shift lever & grind off the piece sticking out & then JB weld the hole shut, & cut off the selector at the bottom that the auto linkage used to hook to.
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! Last edited by t korinek; 01-17-2011 at 03:59 AM. |
