Old 01-17-2011, 01:59 PM   #1
kellytheaker
Alternator bracket mounting - not right
I have a 72 350 - the previous owner felt the stock mounting brackets and adjusting arm had to be thrown out and chrome junk should be installed - now i want it back stock , i thought i had a short waterpump but when i installed the bracket and arm the 1" of adjustment is not right - the alt hits the junk chrome valve covers so i am starting to suspect i have a long waterpump , dimentions from the block mounting is 3" to pulley and 6" from mounting to pump snout where the fan spacer starts , am i on the right track here . I would be very open to the 2 mounting styles but this isnt working .
kellytheaker is offline   Reply With Quote
Old 01-17-2011, 02:43 PM   #2
john
member #16
john's Avatar
Re: Alternator bracket mounting - not right
Here are the pump dimensions.
john is offline   Reply With Quote
Old 01-17-2011, 04:02 PM   #3
kellytheaker
ok from my dimesion it looks like i have the short , so what are the two bracket systems - can anyone provide a pic of both styles - the alt is bumping into the valve cover if you try and use any of the adjustment available . sorry i am not picture capable .
Old 01-17-2011, 05:29 PM   #4
john
member #16
john's Avatar
Heres a pic I saved from this site. It is a short pump with accessory holes in the head.
Old 01-17-2011, 07:01 PM   #5
kellytheaker
just great photos, i am using the same bracketry and the back of the alt , is hitting the valve cover , i suspected incorrect brackets first , then waterpump , i see it measures close enough to the short , alt , may be the problem , not sure yet , any ideas or help
Old 01-17-2011, 08:32 PM   #6
sjarrett71
sjarrett71's Avatar
Try a longer belt to move the alt out further?
-Scott-
sjarrett71 is offline   Reply With Quote
Old 05-03-2012, 11:22 PM   #7
Hogger Brad
I seem to be haveing the same problem. What did you end up doing ?
Hogger Brad is offline   Reply With Quote
Old 05-03-2012, 11:30 PM   #8
Bryan H
Bryan H's Avatar
I believe if you are running the tall style valve covers the factory setup will hit. Seems I had the same problem and had to put a dent on the top corner of the valve cover to keep the alternator from hitting. My valve covers were painted so you couldnt see it behind the alternator.
Bryan H is offline   Reply With Quote
Old 05-03-2012, 11:30 PM   #9
Andy4639
Old member
Andy4639's Avatar
Wink Re: Alternator bracket mounting - not right
It's not the brackets are the pump the valve covers are taller than factory ones so you will need a longer belt to get the alternator further out.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-03-2012, 11:38 PM   #10
Bryan H
Bryan H's Avatar
How do you like that. 2 responses at the same time with the same answer! You can't beat that!
Old 05-04-2012, 12:04 AM   #11
Andy4639
Old member
Andy4639's Avatar
Talking Re: Alternator bracket mounting - not right
