Old 06-29-2003, 11:45 AM   #1
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
Question door help??????
went to open pass.side door on 72 and noticed the button was hard to push but it opened and now the door wont close it just come back open.the handle looks fine and the buton looks normal
would this be the handle or the door latch how hard is it to replace the latch assem..thanks henry
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 06-29-2003, 01:40 PM   #2
BIG ORANGE
BIG ORANGE's Avatar
Henry remove the door panel and check the door handel then if you dont find a problem there then check the latch,it should be one of the two.
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 06-29-2003, 02:05 PM   #3
jef5150
Inline 69
jef5150's Avatar
< now the door wont close> wait!!!!!!!! try THIS first,,,,,when you close the door does it sound like your hitting solid metal,,,,,maybe the star-cam in the door went out of alignment,,rotate it clockwise with your finger till it "clicks" 1 time....then try the door,,,,,,,if this dont work try "BIG ORANGE"S idea
jef5150 is offline   Reply With Quote
Old 06-29-2003, 02:47 PM   #4
72shadetree
KEEP ON TRUCKING
the star cam rotates freely doesn't catch or click. How hard is it to change the door latch assembly?? thanks Henry
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 06-29-2003, 03:07 PM   #5
casey
casey's Avatar
not hard, take the door panel off so you can get inside. theres 3 large philip screws around the latch on the outside, un screw them and the latch will come out from the inside, theres two rods on the latch that have to come off one for the inside door handle and one for the door lock, theres a little snap clip on theses rods you'll see how they come off when you look at it
casey is offline   Reply With Quote
Old 06-29-2003, 03:43 PM   #6
72shadetree
KEEP ON TRUCKING
thanks alot
72 cheyenne 2wd lwb
71 k20 sons
bassett va
