Old 01-17-2011, 09:56 PM   #1
illtemper
illtemper's Avatar
turning a suburban into a panel?
well I searched but found nothing anywhere,I'm sure someone's done it,I've seen the reverse (panel to sub). it might be sacrilege but I'm thinking about covering all the rear glass in my 70 suburban and dropping it to make a (fake) panel hotrod. any and all thoughts appreciated. anyone done this?
thanks...Jon
78 crewcab on a 76 3/4t camper special frame, D60, 14B, 14B, 4.56's ,350sb, 465, 205 twinsticked.
67 kaiser 5ton m52a2, multifuel.
illtemper is offline   Reply With Quote
Old 01-18-2011, 11:13 AM   #2
olblue60@aol.com
member
Re: turning a suburban into a panel?
There are a couple of nice ones out your way! $1500 & $2000 Try searching
Jaxed.com
John
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 01-18-2011, 11:41 AM   #3
illtemper
illtemper's Avatar
Jaxed.com
John
maybe I was unclear,I'm not looking to but buy a truck,even if I could afford it.I'm looking for information about welding steel panels over the windows of my 70 suburban to make a 3 door panel truck,and/or reasons to or not to do it. thank you...Jon
Old 01-18-2011, 01:40 PM   #4
CG
BlahBlahBlah
I was wondering about a similar thing, but on my 58 Ford wagon. I was told you need to be a pretty good welder to not warp such large flat panels of steel.
Old 01-18-2011, 03:02 PM   #5
Hart_Rod
Hart_Rod's Avatar
Just use a piece of 1/4" plate.......
Hart_Rod is offline   Reply With Quote
Old 01-18-2011, 03:55 PM   #6
illtemper
illtemper's Avatar
I said panel truck,not armored truck,lmao. maybe 3/32 or 1/8 tho,just so it won't warp?
Old 01-18-2011, 04:01 PM   #7
463
463's Avatar
i think i would use the auto glue thats used in the body shops or urathane and seam seal to mount the filler panels as opposed to welding them. but that just my take on this.
Trueman
463 is offline   Reply With Quote
Old 01-18-2011, 05:57 PM   #8
illtemper
illtemper's Avatar
interesting,I'll look into that. the shop I called said they'd just 'glass it in.
Old 01-18-2011, 09:58 PM   #9
CG
BlahBlahBlah
You know that's a really good idea. I know next to nothing about these "super glues" body shops use, but the little I have read make this really worth looking in to.
Old 01-19-2011, 05:28 PM   #10
chris mc bride
chris mc bride's Avatar
I know the glue idea would work. IMO if you could fabricate them and then tack weld them in stages,it would be best way. If you tack weld your way around making many trips leaving lots of space between welds warping should not be problem. I woud personaly go the welding approach.
chris mc bride is offline   Reply With Quote
Old 01-19-2011, 10:30 PM   #11
olblue60@aol.com
member
If you look under the "please post pictures of your panels" page three, you will see a short panel orange and white. Member jgb7038. That truck was originaly a long wheelbase pickup that he shortened and grafted a suburban rear on and then filled the windows. He had a complete build thread on here. Perhaps you might contact him for info. He probably would be willing to post a link to the thread again for you.
Old 01-19-2011, 10:35 PM   #12
olblue60@aol.com
member
Here you go! Any questions maybe you can PM him.
http://67-72chevytrucks.com/vboard/s...d.php?t=381531
Old 01-21-2011, 12:16 PM   #13
illtemper
illtemper's Avatar
wow, nice truck. thanks for the link,that's what i was looking for!
hard to tell,but it looks like he made a fiberglass plug to fill the window hole,cool idea.
Old 01-21-2011, 10:00 PM   #14
olblue60@aol.com
member
I believe that the fiberglass look is just from scanning photos to post them. I believe he says that he used 18 gauge metal to fill the windows.
Old 01-22-2011, 06:31 PM   #15
jgb7038
jgb7038's Avatar
The window openings are filled with 18 gauge sheet metal,and the interior trim panel is made from fiberglass.
jgb7038 is offline   Reply With Quote
Old 01-23-2011, 12:09 AM   #16
pritch
pritch's Avatar
I've got some pics of a '63 or so that had been converted. I'll look around and see if I can find them.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 01-23-2011, 12:25 AM   #17
pritch
pritch's Avatar
Not the best pictures of the conversion, but here they are:
This guy always comes up to our local car show. It's really well done. You cannot tell it's converted except for the step is in the 'Burb place instead of the Panel place.
'68 Panel
'68 C-10
Ol' Green
Old 01-25-2011, 02:39 AM   #18
illtemper
illtemper's Avatar
beautiful truck,thanks for the pics.
Old 02-27-2011, 12:49 AM   #19
AzDon
AzDon's Avatar
There usta be a mid-seventies four-door burb around here that had been made into a panel..... He could not get the curvature on the side panels right and you could see where the window openings had been. It might be easier on our burbs because the opening you would sheet is surrounded by the bottom of the raingutter and the top of the body. I think it would be cool to panel over the back door window while leaving the door functional (but shave the handle) You might also consider creating a couple of panels to simply replace the side window glass behind the rear door(s) that are held in place by the glass surround rubber as the side panels in a Vega panel delivery were done.
If you do the project, I know someone that needs your discarded glass
AzDon is offline   Reply With Quote
