turbo 400 kickdown
Anyone have any pics of where and how i should set one up? My trans shifts weak and really quick! its got a shift kit in it and is a low miles turbo 400 under 40k! everything was super clean when we opened it up! thinking the kickdown is the problem and even if it aint i want one anyways lol!
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
Re: turbo 400 kickdown
Here are a few pics. The Kick-Down Mounting Brackets are available at your local auto parts store. Sold under the Edelbrock brand #8036 Anodized, 8030 Chrome, 8031 & 8032 Black.
Its electric, I got one off a newer truck. I added the whole throttle assembly with switch mounted on it and cable throttle linkage.
70 Chevy SWB Fleet Project. 06 Lancer Evolution MR SE, stupid fast! 03 Ford f-250 crew cab, 6spd, diesel 56 ford f100 project My build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=426739 |
Future TOTM Winner
Here are a couple pics from a stock 69 setup, don't know if that helps you much or not.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
so this thing need to be set at full throttle?
![]() Join Date: Feb 2001
I thought the 400 Kickdown switch was on the carb from 70 and older trucks??? From 71 and newer they came off the gas pedal? Maybe i am dreaming????
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 01-18-2011 at 01:28 AM. |
![]() Join Date: Apr 2008
When I ditched my old and worn stock q-jet on my '69 I replaced with a 600 cfm Edelbrock and they did not have a location for the stock kick down switch. I inquired about what I should do from Edelbrock and they said that they sell a WOT bracket and micro switch for their NOS setups and it would work fine. It was more than I wanted to spend for a anodized piece of aluminum and a $2 limit switch. Also I wanted the tranny to shift before WOT so I would not be wasting all kind of gas just trying to drop into gear. I went to the surplus store and bought what I needed for around $3 and made a kick down switch that fits in front of the throttle linkage and I can adjust it to open when ever I want to. I kind of rough wire it to see if it would work and it does just fine. Most of this is temporary because I am going to be installing a 700r4 here soon, so I did not want to get to technical over a short term fix. I did secure the wire a little better since the photo.
![]() here is the original one that did not fit the new carb ![]()
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 01-18-2011 at 04:02 AM. |
