01-18-2011, 08:38 AM | #1376 |
Re: What did you do to your truck today!
Installed my sanderson headers and had exaust tucked up through crossmember and out behind the rear wheels, oh and pinstriped.
71 chevy cheyenne lwb http://s321.photobucket.com/albums/n..._tab_my_albums Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote! |
01-18-2011, 12:28 PM | #1377 | |
PM sent.
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
01-18-2011, 01:20 PM | #1378 |
Florida Edition
From this...
To this.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
01-18-2011, 02:26 PM | #1379 |
71 bb longhorn
RenoKeene what did you use on your panel it looks great.
71 2500 Gmc longhorn with a 402 turbo 400. 09 F150 Supercrew 4x4 05 Mazda 6 sport accept that somedays you are the statue and somedays you are the pigeon. |
01-18-2011, 02:54 PM | #1380 |
Florida Edition
Thanks, Scrubed them down with Dawn (in the bathtub), sanded with 400, scuffed with scotch brite, scrubbed again, cleaned with SEM 38353 plastic and leather prep, sprayed with SEM 39863 plastic adhesion promoter, applied SEM color coat (Santa Fe & Brite White). 4 coats of color.
Will put on 2 coats of Low Luster Clear when it comes in tomorrow. Also going to paint the groove around the scroll body color (not giving away all my secrets!). Did the console to match. VERY IMPORTANT: READ ALL THE SEM DIRECTIONS! Reno P.S. If you are married don't try this in YOUR bathroom.
01-18-2011, 04:06 PM | #1381 | |
Florida Edition
Reno
01-18-2011, 04:15 PM | #1382 |
Licensed to Thrill!
So far today, here's what I have done to my truck
•Drove it to work (in the rain) •Hit the lock button on my remote, the actuator broke inside the door panel •Set off the alarm in my work parking lot at lunch trying to get back into my truck with a broken lock actuator •Got home for lunch and took drivers side door panel off to remove actuator •Remove actuator, go to put door panel back on, and one of the nuts that holds the armrest screw falls of into the door. Get that screw put back in, and start with door panel again. •One of the nuts that holds on the door panel falls out into the door. Get it back in and go to put on door panel again. Repeat this three times. •Get everything back on, and threaten to kick door in. Not really, but I was frustrated. DLB |
01-18-2011, 07:23 PM | #1383 |
Registered Chevy Owner
I really didn't do much of anything to my truck. One of my wippers was squeaking so I took the cowl off to squirt it with some lube. I swapped out one of my side mirrors legs (I have tripod mirror mounts and was deciding if I liked the long or short legs. I went with the short), I squirted some white lithium on my pass. side window tracks 'cause it was getting a little tough to roll up and down, I decided to put the original glove box door back in, and last thing I did was detail the inside a little (clean it up a little really). So ya not much to really speak of.
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
01-18-2011, 08:02 PM | #1384 |
I've been disassembling the Blazer for the past couple of weeks to get it ready for body and paint in mid February. I have a ways to go yet.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
01-18-2011, 08:29 PM | #1385 |
yes, i do
took the heads, tpi plenum-runners-base, and the intake off of the old engine in to be cleaned and checked. heads are getting a full overhaul with new guides and found that my tpi base is cracked so now i gotta source out a new one. but i did order a set of tubular engine frame mounts off ebay since i let the old engine mount pads go with the old engine. these are the ones that i got.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT at least i have a couple of passenger saddle style engine mounts sitting in my garage somewhere. besides i've been wanting to get some of these anyway
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
01-18-2011, 11:40 PM | #1386 |
Under Construction
I bought 100 sq. ft. of Fat Mat for my truck. Hope to stick that on this Saturday. Yesterday I bolted the doors and fenders back on. I'm slowly getting it back into 1 piece.
72 chevy 4x4-my project 67-72chevytrucks.com/vboard/showthread.php?t=368210 94 Nissan 4x4-Daily Driver and off road beater 03 Saab 9-3 -tripper 90 Polaris Trail Boss- 2 Stroker |
01-19-2011, 12:21 AM | #1387 |
Adjusted out of wack toe in enough to drive to alignment shop tomorrow.
Threaded a brass fitting into rear end to hook up vent hose. Centered rear end. Installed new glove box and ash tray bumpers.
"Once a Chief, always a Chief!" MCPO (ret) 03 2500HD- 'Daily driver' 67 Short Fleet- 'Drivable project!' 11 Malibu LTZ- 'The Wife's ride' |
01-19-2011, 12:29 AM | #1388 |
got some more parts to fix some of my brake line issues, and some 67 armrests.
01-19-2011, 12:34 AM | #1389 |
that is an optical illusion! you think you want and need those arm rests but you dont what you need to do is send em to me!
01-19-2011, 12:52 AM | #1390 |
haha. and i got them both for about $12 and some change from the salvage yard, was gonna grab the fender the was really strait except the rust in the front lower corner so i ended up leaving it because of that reason
01-19-2011, 12:54 AM | #1391 |
well ill give you 15 for em was the fender the passenger side?
01-19-2011, 12:56 AM | #1392 |
Removed windshield wiper motor and linkage etc. Removed windshield (in pieces). Removed kick panel vent doors. Removed headlight and wiper switch. Removed dome light. I figure I will be ready to spray over cleaner all over the inside of the cab by this weekend.
Posted via Mobile Device |
01-19-2011, 01:00 AM | #1393 |
01-19-2011, 01:01 AM | #1394 |
i have a clean 68 fender and would love to have that fender! was it rusted through the hole front cup or was it just a small peice
01-19-2011, 01:07 AM | #1395 |
almost the whole bottom of cup, poked at it a little bit after i pulled the rags out of it, and the hole started growing
01-19-2011, 01:08 AM | #1396 |
so would i need to cut the whole cup from the the body line down
01-19-2011, 01:14 AM | #1397 |
most likely
01-19-2011, 01:25 AM | #1398 |
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
01-19-2011, 12:00 PM | #1399 |
RAT1968 '68 Cab/'71 Parts
You can drive it though, huh?
Some of these days, when it's cold and wet, and generally depressing, I forget that I LIKE to wrench. On these days, I'd rather have a truck that's as nice as yours (hell, wouldn't even have to be THAT nice) that I could tinker with if I wanted to...And drive it in the mean-time. In my experience, that's a great way to save money, too. For me, tinkering's dangerous. It leads to the hard stuff. That new truck of yours looks very sweet.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 01-19-2011 at 12:02 PM. |
01-19-2011, 12:29 PM | #1400 |
Replaced the battery and added more tranny fluid. Now off to register and get new custom plates. I may also order my drop spring and leafs but gotta check the wallet first!
