Old 01-19-2011, 07:28 PM   #26
Kurt L
Kurt L's Avatar
Re: Questions about 86 truck not starting.
put a little grease on the end of the pump rod. that way it''ll let you get that pump up into the engine. worked for me before.
Kurt L is offline   Reply With Quote
Old 01-19-2011, 07:33 PM   #27
Mrtn15
Mrtn15's Avatar
So if I buy this, will it include everything I need?
http://www.skipwhiteperformance.com/...x?Item=PC-2751
1986 Single cab 2WD Chevy 350/350
1977 Single cab Dually C30 BB454!
Mrtn15 is offline   Reply With Quote
Old 01-19-2011, 07:54 PM   #28
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Look man, don't buy that fuel pump you linked to. Go to the local parts store and get a stock one for about 20 bucks. It will fit right. That fancy one you linked to has universal fittings and you're going to be chasing around finding the proper fittings you need. Just buy the right pump and put it on and save yourself the trouble.
And, there is no reason to buy a fuel pump push rod like the other guy posted about twice. Why would you ? It's a piece of hardened steel that doesn't fail.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-19-2011, 07:57 PM   #29
Mrtn15
Mrtn15's Avatar
Will the new one be pretty? & Where exactly is this "fuel pump push rod" located ? in the fuel pump ? or what ?..
Old 01-19-2011, 07:59 PM   #30
Prerunner1982
Prerunner1982's Avatar
Is this a dual tank truck? If so do both tanks work? If one does not work.. check the switch to see if it got switched to the wrong tank on accident.
I know from experience....when I thought my fuel pump was out and proceeded to try and pull the tank... to find out the switch had been flipped by my 4yr old.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 01-19-2011, 08:05 PM   #31
Mrtn15
Mrtn15's Avatar
Where is the switch? My right tank does work. but has no gas in it.. and My switch doesnt really work all of the time..
Old 01-19-2011, 08:15 PM   #32
rhdowns
I agree with the grease on the end of the rod that does help it if you don't have someone to hold it up in there when putting the fuel pump on. Did that when I put mine on as well.
You do not have to buy a new rod but that rod which is hardened steel rubs against a cam shaft for tens of thousands of miles. I replaced mine it was cheap probably more important for me as mine was going against a new camshaft.
I got the fittings for that pump at advanced auto for a couple dollars. I agree go whatever the cheapest route is for you specially if you do not have a trimmed out motor and no plans for that.
Didn't realize you had two tanks. My truck only has one so definitely explore that route as well.
Great feedback here - really enjoy this board.
86 K10 Shortbed
Skip White 383 \ 700R4 3.73 rear
rhdowns is offline   Reply With Quote
Old 01-19-2011, 08:26 PM   #33
Tx Firefighter
Don't take my previous response as disrespect to your opinion. There are reasons to change a pushrod as you pointed out. But, this guy is struggling to swap a fuel pump on his truck. I felt no need to further complicate the matter for him.
On the fuel pump, a decent Carter brand or equivalent at the local parts store will run 20 bucks or so and will have all the proper hose and line fittings all pointed in the right direction for his feed, vent, and outlet connections. It will be a remove and replace job. That fancy one is not going to be easy for him to get installed and hooked up on his truck since it's universal and has no fittings on it.
Old 01-19-2011, 08:32 PM   #34
Mrtn15
Mrtn15's Avatar
That's exactly what I want.. quick and easy! And i was hoping that a new shiny one would be as easy to install as a stock one. I do have edelbrock valve covers carb and 14" cleaner and im soon getting the intake. and timing chain cover. So, I do want the chrome pump, but if it's that much trouble.. I don't really care! I just want to drive my truck again.. and I don't even know how to Change the pump. I will figure it out.
Old 01-19-2011, 08:32 PM   #35
Prerunner1982
The manual switch you push is in the middle of the dash. The actual switch for the tank is by the tank on the passenger side. It is mounted to the inner side of the frame.
Jon
Oklahoma Roll Call
Old 01-19-2011, 08:34 PM   #36
Mrtn15
Mrtn15's Avatar
The switch used to work, I would hear it switch and everything.. but recently it stopped. and I had gas leaking from a hose on the switcher that looked cut, it was a hard plastic and about the width of a straw. Both of my tanks did work before though. but this hose has always been like that. and it only leaked like that for one day! thenext day, it didnt leak.
Old 01-19-2011, 08:47 PM   #37
rhdowns
No offense taken at all great options you pointed out.
86 K10 Shortbed
Old 01-22-2011, 05:08 PM   #38
Mrtn15
Mrtn15's Avatar
okay, so I have had the pump for 2 days now, and I can NOT get it into the motor I don't understand how to do it, I lift the pump rod and hold it there with a screwdriver! but I cant get the pump into the motor.. Does the little handle go into a hole or womething ? what
Old 01-24-2011, 08:19 PM   #39
Blue Chevy 1987
Blue Chevy 1987's Avatar
the rod has to go in the motor on same side of cam as old came out....
Blue Chevy 1987 is offline   Reply With Quote
Old 01-24-2011, 09:21 PM   #40
Mrtn15
Mrtn15's Avatar
Whoaa I got it guys! My truck is running!!!
adivce, chevy c10, dead, fuel pump, gas
