Old 01-22-2011, 12:27 PM   #1
67cheby
67cheby
67cheby's Avatar
looking for billet wheel polishing tips
any certian brand of polish, any polishing tips, any coating ideas for after the polish
67cheby is offline   Reply With Quote
Old 01-22-2011, 01:08 PM   #2
Shane
Shane's Avatar
Re: looking for billet wheel polishing tips
here's an awesome article on the basics of billet wheel polishing
Shane is offline   Reply With Quote
Old 01-22-2011, 01:09 PM   #3
Wootdog
Wootdog's Avatar
One word Flitz. It is expensive but you can polish anything with it.
Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 01-22-2011, 01:11 PM   #4
67cheby
67cheby
67cheby's Avatar
thanks for everyones tips , keep em coming
Old 01-22-2011, 01:34 PM   #5
Wootdog
Wootdog's Avatar
Flitz is what Street and Performance in Mena, Arkansas uses on their engines trannys, and other billet parts. That is what I use to polish my engine (LT1) and Weld Pros Stars. (Which I need to do before I pull it out of the garage again). You do the old Weld Wheels up and don't have to polish them again for a few months.
Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 01-22-2011, 02:16 PM   #6
cdowns
cdowns's Avatar
most billet wheels need thier original finish clear coat or whatever stripped b4 any polishing can b done
Old 01-22-2011, 04:36 PM   #7
SactoJim
SactoJim's Avatar
Billet wheels typically don't have any clear coat on them. Clearcoats are typically on the high production cast type wheels.....Eagle, American Racing, etc.....
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 01-22-2011, 05:31 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That is the exact same link I was going to post.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-22-2011, 05:48 PM   #9
67cheby
67cheby
67cheby's Avatar
great article
Old 01-22-2011, 07:35 PM   #10
Shane
Shane's Avatar
it looks silly, but you would be amazed at the finish you get by "buffing/rubbing" the compound with nothing more than your finger ...
Old 01-22-2011, 07:52 PM   #11
There is a message board on this site specifically for this topic. It's called "detailing".
Old 01-22-2011, 09:18 PM   #12
jcblue
jcblue's Avatar
smith brite
jcblue is offline   Reply With Quote
Old 01-23-2011, 12:33 AM   #13
piecesparts
Parts and more parts
piecesparts's Avatar
If you have a set that is really dirty, then there is a way to clean them without a lot of elbow grease. I use what is called razor buffs on a die grinder, with a polishing brick to clean the metal and get the polish started. A razor buff is usually a 3' or 4" buffing wheel that can be attached using a pointed tool on the die grinder. It is easy to get into tight spots and cut the metal to get the smooth finish started.
I use Mothers aluminum polish with a power ball to get the next step going and then finish with Mother's Billet polish to get the mirro finish. I then seal the metal with a metal sealer from one of a couple sources, to keep the road dust and dirt out of the pores. I usually do my wheels twoce a year to keep them clean.
Looking at the attached write-up, I di remember some of the older guys using flour, but had not approached that thought in many years. I think that will be my next trial going into this coming spring.
Frank
Old 01-23-2011, 01:59 AM   #14
PTS
Junior Member
PTS's Avatar
Use a product called Mothers Billet Wheel Polish. Use a soft terry cloth, fold into a small thick square and polish with the grain of the wheel. If you rub in a circle motion you will create swirls which means lots more work. Always continiously refold cloth or replace. Another tip is to use some spray detail like Mothers Quick Detail on the cloth you intend to remove the polish and this help lift the polish without scrubbing and again remove with the grain of the wheel.
Regards,
Perry
PTS
Great Deals for 67-72 members on Billet Specialties, Intro Wheels, and Ridetech!
Toll Free 1-855-353-7885
PTS is offline   Reply With Quote
Old 01-23-2011, 03:19 AM   #15
Musclerodz
Flitz, nothing else needs to be said
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 01-23-2011, 03:29 AM   #16
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
They look *****in...but they are a ton of work....good article though...thanks for posting.
-Ron-
OldSkool71 is offline   Reply With Quote
Old 01-23-2011, 03:46 AM   #17
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Mothers Billet Polish
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 01-23-2011, 10:08 AM   #18
bigsnookmaster
bigsnookmaster's Avatar
I use a German product called Autosol. It's a paste thats been around for a while. It's available at some E-bay stores. Great stuff!
bigsnookmaster is offline   Reply With Quote
Old 01-23-2011, 10:30 AM   #19
jmedero
jmedero's Avatar
Mike I own a detail company and have tried a million products for all the custom cars and the custom bikes we do. The best thing I have found so far is called white diamond found at some auto parts house. I start off with the power ball then move to hand polishing with a latex glove on my hand. Sounds silly but it makes a diff. When your done it will be like A mirror.
Juan
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 01-23-2011, 11:12 AM   #20
7T2
Active Member
7T2's Avatar
I get ticked off every time I see one of those guys at a swap meet talking about how great the Mothers Powerball is. It might work if you have completely smooth wheels, but forget it if you have anything with spokes, like polished Torq-Thrusts. Mine didn't even last a day before it started shredding little bits of foam all over my wheel, then it came loose from the stem that holds it in your drill. I will never go near another one, even if it is free.
On the other hand, I have been using a Flitz Ball for three years now with glorious results. It is about the same price as the Mothers ball, maybe a little more, but it is well made, washable, and it is a product that works. Highly recommended.
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 01-23-2011, 11:43 AM   #21
piecesparts
I found that the tapered foam cone that Mothers sells is far better for any thing than the power ball. I purchased it and, YES, there is some cutting on the foam but it lasts a lot longer than the ball. You can even get into tight spots with it. I have spoked rims and also some rims that are not spoked, that have some edges that could cause issue with the foam. It works well.
Frank
Old 01-23-2011, 12:29 PM   #22
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Can't wait to see how the flour woks for you...
Regards,
Perry
PTS
Great post PTS.
-Nate
Old 01-24-2011, 11:22 AM   #23
67cheby
67cheby
67cheby's Avatar
great info from everyone, Thank you and keep it up if anyone else has any more tips
