Old 01-23-2011, 12:02 AM   #1
Mrtn15
Mrtn15's Avatar
Unhappy New fuel pump, still no start..?
Okay, usually on cold mornings my truck Just fires up first turn of the key, no pumping on the gas, nothing. This morning, My truck did not start.. I pumped on the gas, and it tried once, but nothing. It turns over, but never tries to run.
People here told me that this was my fuel pump.. So I changed it! And in the process of changing it, i cut the metal line that runs from the pump to the rubber hose that connects to the carb. I replaced all of that with just hose; And a fitting that connects to my fuel pump.
Needless to say, My truck STILL WONT start..
I need help.
1986 Single cab 2WD Chevy 350/350
1977 Single cab Dually C30 BB454!
Mrtn15 is offline   Reply With Quote
Old 01-23-2011, 12:07 AM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: New fuel pump, still no start..?
dual tanks? Maybe the fuel selector valve?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-23-2011, 12:08 AM   #3
Mrtn15
Mrtn15's Avatar
Yeah I have dual tanks.. And what is the selector Valve? the switch inside; or the switch under my truck by my passenger side tank?
Old 01-23-2011, 12:14 AM   #4
JuicyJ
JuicyJ's Avatar
Did you check you if you have spark at the plugs. If not check your ignition module or coil, and also make sure your fuel pump is pumping fuel. Start with basics.
America is all about speed, hot nasty bad ass speed
JuicyJ is offline   Reply With Quote
Old 01-23-2011, 12:17 AM   #5
Mrtn15
Mrtn15's Avatar
Thanks JuicyJ;
I put the 8th plug on my wiper, and saw a spark when I turned it over. and now on the pump, It's new! I lifted the rod, put the pump in, bolted it, and connected the hoses( along with the hose I made) my custom hose should work right ? its the size of the metal one I cut off !
Should I change all of my plugs now or now?
Old 01-23-2011, 12:30 AM   #6
JuicyJ
JuicyJ's Avatar
I have had new fuel pumps fail on me and it's better to be sure you have fuel so you can eliminate the fuel pump and look elsewhere. Just put a container on the fuel line to the carb and have someone crank it. If you see fuel you are good to go. Then you can start looking elsewhere. Alot of people on here will help you out with other things to check.
Old 01-23-2011, 12:38 AM   #7
Mrtn15
Mrtn15's Avatar
Okay, Thank you ! I check this.. and there's no fuel
Old 01-23-2011, 12:41 AM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
Dump a small amount down the carb, if it is firing, it should at least try to start. That will tell you if the spark is there.
Frank
Old 01-23-2011, 12:46 AM   #9
Mrtn15
Mrtn15's Avatar
I have also done this, before I took the old pump off, It would try! and it hasn't tried today.
Old 01-23-2011, 01:07 AM   #10
JuicyJ
JuicyJ's Avatar
So if you pour gas in the carb it doesn't start? And you have a good spark, and your plugs make sure they are not fouled out. If no fuel from the pump take it to the parts store and get a new one I am sure they will warranty the exchange.
Old 01-23-2011, 01:11 AM   #11
Mrtn15
Mrtn15's Avatar
only thing is, my box kind of flew put of my truck. So I will just buy a new one! and no, no fuel from pump. Thanks for your help! I will check ALL my plugs tomorrow.
Old 01-23-2011, 02:54 AM   #12
jgaona05
I recently had a similar problem. My truck was cranking fine then one day nothing, I went through 2 pumps and a new set of spark plugs. To rule out the selector switch under the truck, I went around it with a 3/8 rubber line from the tank with fuel over to the fuel pump feed line and BINGO!! I had fuel and the truck cranked. Maybe you've checked that already, figured it couldn't hurt to post anyway.
jgaona05 is offline   Reply With Quote
Old 01-23-2011, 02:56 AM   #13
Mrtn15
Mrtn15's Avatar
I have not checked this, what should I do? What do I run the line from?
Old 01-23-2011, 02:57 AM   #14
Mrtn15
Mrtn15's Avatar
I run it from the tank to the pump? Which line is this
Old 01-23-2011, 03:03 AM   #15
jgaona05
My truck is an 80 , I don't know if there is a difference in design. But I followed the hard line coming from my driverside tank in the selector switch and disconnected it at the switch. The I found the line going from the selector switch to the pump and disconnected it at the switch. I connected those 2 ends with 3/8 fuel line. It sounds complicated, you basically bypass the selector switch with rubber line
Old 01-23-2011, 03:05 AM   #16
jgaona05
You'll only need maybe 12 inches of hose. From hardline to hardline. I guess Its more of a selector valve, not switch
Old 01-23-2011, 03:07 AM   #17
Mrtn15
Mrtn15's Avatar
Oh okay! That sounds easy enough! Thanks man! I will try this in the morning and get back to you! I will check my plugs first!
Old 01-23-2011, 06:42 PM   #18
jonessmc87
jonessmc87's Avatar
I know this sounds stupid but it happened to my friend on his pontiac 400. The mechanical fuel pump died so he bought a replacement. The pump looked IDENTICAL but after much determination through these same problems, the inlets and outlets were swapped. So his hard line from the carb was hooked up to pump inlet and the outlet was plumbed to the tank. He was essentially pumping fuel out of the bowl back to the tank. We were sitting there cussing at the pump until i had it in my hands and pumped it and noticed the suction on the wrong fitting. Once we swapped lines it fired right up.
1989 V3500 nv4500/np205 255-85-16 BFG Mud Terrains, 4inch skyjacker kit, 2 inch body lift.
"Yea, it was a fuel supply problem. A rod came through the block and cut the fuel line."
jonessmc87 is offline   Reply With Quote
Old 01-23-2011, 06:48 PM   #19
Mrtn15
Mrtn15's Avatar
Well,I had a business call, so I'm away from my truck at this moment. I will definitely check this later though!
Old 01-24-2011, 10:03 PM   #20
Mrtn15
Mrtn15's Avatar
I got it fixed, and running! Thanks guys.
Old 01-24-2011, 10:13 PM   #21
jgaona05
Hell yea That's good, what did it end up being?
Old 01-24-2011, 11:34 PM   #22
Mrtn15
Mrtn15's Avatar
I'm guessing the pump? I ran a new pump, and all new gas lines!
chevy, dead, fuelpump, help wanted, idiot
