Old 01-23-2011, 10:49 AM   #26
rob32472
Re: LSx swap Speedo ?
Originally Posted by menace121978 View Post
subscribing... i'm hooking up my autometer speedo now but i was looking over the wiring diagram for it and it says there is supposed to be 2 wires for signal input. 1 from the computer and one from the tranny. i'm stumped because i only have 1 wire. and its coming from the computer. any input on this?
one goes to the speedo connection the other to ground..... I just finished the swap with autometer gauges and it works perfectly!
rob32472 is offline   Reply With Quote
Old 01-24-2011, 10:23 AM   #27
menace121978
menace121978's Avatar
right on! at least i know its hooked up right thank you
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 01-24-2011, 05:50 PM   #28
rob32472
Glad to help!
Old 01-26-2011, 12:22 AM   #29
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I have my 91 gauge cluster vss wire comming from the pcm. theres an output for it. im sure all speedos work in similar fasion, the only thing that will change is the Pulses Per Mile, which can be adjusted if you have a tuning program.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 02-23-2011, 09:21 PM   #30
60apache
60apache's Avatar
Originally Posted by Clyde65 View Post
I did, you have to hook it up at the VSS out wire by the trans and THEN calibrate it. Dont let anyone tell you to hook it up out of the PCM, it wont work properly.
I was trying to get my dolphin speedo working and reading correctly today I have it spliced to the purple wire on the vss going to the green wire on the back of gauge. it works but needs to be programmed. can you look into your gauge and give me the numbers you have programmed so I will have a starting point?
60apache is offline   Reply With Quote
Old 02-23-2011, 09:32 PM   #31
60apache
60apache's Avatar
oh is your speedo one with dip switches or a button?
Old 02-24-2011, 10:55 AM   #32
Clyde65
Clyde65's Avatar
I can do that for you, all I did really was set it up and tweeked it twice, I will get you that info at lunch.
sorry it has a button. do you have the provision for a button on the back? or is it only dips
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-25-2011, 07:51 PM   #33
60apache
60apache's Avatar
mine it the button type.
Old 02-26-2011, 07:59 PM   #34
60apache
60apache's Avatar
clyde I got mine hooked up to the vss wire from the trans and calibrated it to 160 frequency its dead on but when I stop it does what yours was doing and pegs out. how did you correct this?
Old 03-17-2011, 06:29 PM   #35
68chevyLQ4
68chevyLQ4's Avatar
About to do this myself. Answer to this question would be great help.. Thanks!
6.0 lq4 / 4L80E
68chevyLQ4 is offline   Reply With Quote
