Old 01-24-2011, 12:22 AM   #1
72gmcshorty
72gmcshorty's Avatar
Recommend a rear setup...
I have my frame apart and was wondering what is a recommended setup for lowering the rear as low as possible without altering the floor. Right now i have 2 bags. What other products would be useful?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 01-24-2011, 01:17 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Recommend a rear setup...
We offer a couple different variations of a "Stage 2" kit that will accomplish what you are looking for. Here are a couple build threads with our Stage 2 kit:
http://67-72chevytrucks.com/vboard/s...d.php?t=414742
http://67-72chevytrucks.com/vboard/s...d.php?t=438156
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-24-2011, 11:22 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I recommend the above mentioned Porterbuilt products!^^^
If you can't fit them in your budget,... at least install a set of rear shock relocators, a good set of quality drop shocks, and an adjustable track bar. (panhard bar)
Keith
Convert to disc brakes.
Old 01-25-2011, 11:08 PM   #4
72gmcshorty
Does your truck have a notch? Unfortunately, i can't afford the PB stuff... my plan is a notch, shock relocators, shocks of some size, and a trac bar. I am not sure of do i need the super trac bar or regular adjustable one.
1992 Gmc 2wd
Old 01-25-2011, 11:22 PM   #5
lolife99
lolife99's Avatar
I like the Super Track Bar from ECE, with a max static drop (5"-7.5" rear drop) or bagged drop.
My red '69 has a 6" rear spring and a 1.5" block with a bolt-in c-notch, shock relocators and drop shocks.
My '71 blazer is bagged with the same notch, 2" blocks, shock relocators and drop shocks.
Keith
Old 01-25-2011, 11:53 PM   #6
PBFAB.COM
PBFAB.COM's Avatar
We also offer a "basic" version of the stage 2. It allows you to keep your factory trailing arms and factory trailing arm x-member. It includes our 2-piece notch, shock relocator system, shocks, trac-bar, bags, and all hardware/bracketry. You can e-mail me or pm if you have any questions.... if my product isn't within the budget, I will still be happy to help you find something that works for you.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-26-2011, 02:48 AM   #7
CheyenneShop
CheyenneShop's Avatar
Nate - do you recommend using a block with this kit? 1"-2"? thanks
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 01-26-2011, 04:55 AM   #8
franky69c10
chevy runs deep
franky69c10's Avatar
Nate how much is this kit again? Btw I'm gonna have 2 take a trip 2 ur shop sumday
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 01-26-2011, 11:42 AM   #9
PBFAB.COM
PBFAB.COM's Avatar
A block is not needed with this kit due to our shock relocation system (if running the shock relocator kit from CPP or ECE it is recommended to run the block to have a little extra room with the shocks. These kits wil work, but the shock angle is far from optimum).
With the basic kit (uses factory trailing arms), your axle will bottom out in the notch before the bags and shocks reach their maximum compression.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-26-2011, 11:45 AM   #10
PBFAB.COM
PBFAB.COM's Avatar
Franky-
The basic kit runs $699
It includes:
Slam SS7 bags (2)
KYB shocks with mounting hardware
Shock relocation system
Porterbuilt trac-bar (fully adjustable with rod ends and hardware)
Porterbuilt 2-piece notch with all mounting hardware.
Here's a link:
http://porterbuiltstreetrods.com/sit...y-version-699/
Just give me a call to set up a time and you are welcome to come visit.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-26-2011, 12:23 PM   #11
djw32
Franky-
It includes:
Slam SS7 bags (2)
Here's a link:
Nate,
How did you route the exhaust with this setup?
Also, Nate was nice enough to show me around his shop a few months ago. He really is a cool guy.
djw32 is offline   Reply With Quote
Old 01-28-2011, 01:47 PM   #12
djw32
ttt
