Old 01-26-2011, 03:10 PM   #1
landsub
New member with some ???
I just bought this burb last week and I cant wait to get started on it. Its a 91 v1500. It currently has 203k miles on the original motor. Transmission was rebuilt 5k miles ago since it developed a leak. I need to replace one of the hoses now due to a leak. Electronic trans cooler is on the way and replacing the radiator with a 4 row unit. Also adding full exhaust, new intake setup, and msd ignition. Im looking on putting a 6" lift and 37-38" tires. I have a set of 3/4 ton axles lined up to go in and maybe rebuilding the transmission to be a little bit heavier duty. Now would I need to order a lift kit for a 3/4 ton truck?
landsub is offline   Reply With Quote
Old 01-26-2011, 09:31 PM   #2
Psycho71
Psycho71's Avatar
Re: New member with some ???
You'll need a kit for the blazer/jimmy/suburban. I'm guessing the main difference would be the rear springs, heavier than those for a truck.
Here's a link to Rough County's site for the their lifts.
http://roughcountry.com/chevy_77-87.html
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 01-27-2011, 09:33 AM   #3
landsub
Thanks for the help.
I was finally able to upload some pics. I need to get better ones though
Old 02-03-2011, 05:55 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
Thumbs up Re: New member with some ???
looks nice and clean
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 02-04-2011, 02:30 AM   #5
iluvmy72
do what I did....get a used set of one ton springs....mine are from a ambulance.
iluvmy72 is offline   Reply With Quote
Old 02-06-2011, 08:48 PM   #6
Patriot
This
Patriot is offline   Reply With Quote
Old 02-07-2011, 12:11 AM   #7
Psycho71
Psycho71's Avatar
Good lookin' rig right there!
Old 02-08-2011, 08:29 AM   #8
landsub
Thanks guys. I will try to get pics of the interior.
