Old 01-27-2011, 01:19 AM   #1
RollinKaos
RollinKaos's Avatar
Power Booster
Does this even make sense to do? I have a '63 currently with 4 wheel drum brakes. I want to go front discs and drop spindles but really dont want to spend the money right now. I have a 77 blazer that I am parting out. I was considering using the booster and master cylinder off of it on my truck. I realise this will not give me more stopping power just a less force on the pedal.
My questions are basically ... Is this a waste of time? If I do this can I still use the 2 chamber master. I am thinking I will need to get a different proportioning valve (CPP?) for a drum / drum set up if I do. Thoughts?
Betty :
'63 Fleetside Longbed
350 w/ 4 speed
CPP 3/5 drop with front sway bar.
RollinKaos is offline   Reply With Quote
Old 01-27-2011, 01:42 AM   #2
Captainfab
60-66 Nut
Re: Power Booster
You can use the '77 booster, many guys do. You will just have to drill some holes to mount it. As for a master cylinder, what I am using is one for a '67-'70 with power brakes. I also use the 'proportioning valve' from the same '67'-'70 truck. I don't know if it is actually a proportioning valve, but more of a distribution block.
Old 01-29-2011, 07:00 PM   #3
RollinKaos
RollinKaos's Avatar
Re: Power Booster
Thank you sir.
Betty :
350 w/ 4 speed
Old 01-29-2011, 10:12 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Power Booster
Ive gotta 72 MC PROP VALVE BOOSTER/BRACKETS for sale, PM me
John
1999 Toyota Tacoma 4x4
Old 01-30-2011, 01:54 AM   #5
Heater63
Heater63's Avatar
Re: Power Booster
As long as your running drum/drum, you just need a distribution block, as all wheels need to "see" the same pressure at the wheel cylinders.
It's when you install front disc's that you will need to install an adjustable proportioning valve, as the disc's and drum require significantly different pressures.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 01-30-2011, 10:26 AM   #6
hardwaa
hardwaa's Avatar
Re: Power Booster
I used the proportining valve out of a squarebody on my truck. At first I had 1972 chevy truck master and booster that I bought new from NAPA. I searched for the stock bracket to mount the booster to firewall which made the instalation a snap. Eventually I took of booster and bracket off now just have 1972 master bolted to firewall. With my biasply tires I wanted more feel of my brakes plus it looks way cleaner. My proportining valve is tucked inside drivers frame in front of upper A-arm.
Not the best pics below but you can see the difference. Hope this helps??
I LOVE BURNOUTS:metal
NO BOZO's
hardwaa is offline   Reply With Quote
Old 01-30-2011, 06:27 PM   #7
RollinKaos
RollinKaos's Avatar
Re: Power Booster
Looks cool. I am just looking for a little more driveability. I honestly dont mind the 4 wheel drum brakes. I am going to go with a 5 speed tranny this summer too. Just want to make it more fwy speed friendly.
Betty :
350 w/ 4 speed
