01-27-2011, 02:55 PM | #1 |
O-Ring Install & Evap, Drier Opinions - THANKS!
Hey guys,
I just mocked up the evap and drier tubes and am getting ready to do the o-rings. Seems easy enough, a bit of supplied oi and the correct o-ring...tighten correctly... Just thought I would put it out there in case anyone sees a possible problem...this is my first time doing AC...hate finding mistakes after the fact. I don't have a manual to refer to for this and see the drier has the words evap and condensor...do the lines look correct...any tips? Thanks, Roger Last edited by BlackTopMotors; 05-19-2011 at 10:25 AM. |
01-27-2011, 05:41 PM | #2 |
member #16
Re: O-Ring Install & Evap, Drier Opinions - THANKS!
Your evap- cond. lines look backwards to me. You have the cond line into evap port on the dryer. They usually have a directional arrow on them.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 01-27-2011 at 05:43 PM. |
01-27-2011, 06:06 PM | #3 |
I think you are right! For some reason i thought cond ment to the compressor and evap I was thinking the condensor....I will just rotate the drier change the tubes...Thanks!!!
Any other tips are greatly appreciated. Roger Last edited by BlackTopMotors; 05-19-2011 at 10:25 AM. |
01-27-2011, 08:46 PM | #4 |
Project Junkie! Fishing Poor!!
Looks like you are missing your A/C Inlet & Evaporator Tube Grommets that protect the aluminum tubes from the core support. We make them.. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
01-27-2011, 09:23 PM | #5 |
Would there be any advantage to using a bit of teflon tape in addition to the o-rings...I want to make sure no leaking...?
01-27-2011, 10:10 PM | #6 |
The o rings do the sealing tape is not to be used. Also keep in mind that the dryer has a desiccant inside to absorb moisture so the system should be kept sealed. The drier is normally the last thing installed so moisture is not added to the system. If your still fabing up the system keep the lines capped and sealed as you wrk on it. Good Luck
Fuzzy |
01-29-2011, 01:32 AM | #7 | |
01-29-2011, 10:03 AM | #8 | |
I never bought anything from ackits.com but I've read good things about them. I had to look the part up for a 1972 Chevelle but they have them for $17.16. You SHOULD be able to find one at the local auto parts store. https://www.ackits.com/pc/37-13218/C...+-+Accumulator When you get your new one leave it sealed until you are ready to evacuate the system and charge it up. Just keep mocking up with what you got.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
01-29-2011, 03:44 PM | #9 |
Good info guys. I am going to be doing my AC system soon, so I am interested as well.
67 5.3L Build |
01-29-2011, 08:52 PM | #10 |
Active Member
When I was doing 134 conversion several years ago I always had problems with orings leaking even when oiled with compressor oil got some of nylog and now I wouldn't put one together without it. One bottle goes a long way.
http://www.ackits.com/c/Nylog/Nylog+...brication.html
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
01-30-2011, 10:26 PM | #11 | |
01-30-2011, 10:32 PM | #12 | |
I don't know much about Air Cond so this will prepare me for other future projects as well, Roger |
