01-27-2011, 09:06 PM | #26 |
Re: The 67-72 One Ton Brake Booster Swap Guide ***PICS***
Here's some pics!
01-27-2011, 09:57 PM | #27 |
That a good looking unit! But all I was trying to say is, If your booster goes bad, and there is nothing wrong with your master cylinder, its possible to just swap in a 1 ton booster, and it will work properly, and greatly improve your braking.
I had no reason to replace the brackets, master cylinder, proportioning valve, etc... That would have been a huge waste of money.. $90, and my brakes work better than new! |
01-27-2011, 11:25 PM | #28 |
So, I can use my existing master cylinder and just swap out the booster. Sweet. I need to do this. I've noticed that sometimes I don't have enough braking power even with 33's I'm anxious to try this swap.
01-27-2011, 11:28 PM | #29 | |
Yep, the little rod between your booster and master cylinder will have to be reused with the 1 ton booster. The 1 ton booster comes with a rod that is much shorter. |
01-27-2011, 11:30 PM | #30 |
Keeping the thread clean since it's supposed to be a guide...
There is absolutely nothing wrong with just upgrading the booster. A number of guys have done just that. I started this thread to answer some of the common questions that a number have come across when doing the swap. As mentioned in the first post, out of shear convenience I elected to get the master too. Posted via Mobile Device Last edited by AJs72K5; 01-28-2011 at 12:13 AM. |
01-27-2011, 11:39 PM | #31 |
@ AJ. You almost ready dude?
01-28-2011, 04:01 AM | #32 |
Just what I needed!!!
01-28-2011, 04:13 PM | #33 |
SWYfor5 - did you buy that all as a kit? New parts? Needing to replace all my braking components when I get to that part of my resto and that seems like an easy way to go...
01-28-2011, 06:31 PM | #34 |
SeventyOne, yes, I bought it complete as you see in the pic's. All new parts. It is a sweet setup, cost just over $300.00, but well worth it to me as in not having to search around and find all the right parts. Bought it from boardmember Frank/aka/Pickmup. Great guy to deal with, and man this is a nice setup, can't wait to get it installed! When I first started researching this swap, he didn't sell this combo, but he designed this setup with the prop valve for 4 wheel disc's and should work great! Check him out! He is in Olympia, Wa.
03-28-2011, 06:16 PM | #35 |
The pic beneath is exact master cylinder and booster as the one on my K5. Where did you go for brake lines... I m having trouble finding the correct sizes to fit front and rear after my conversion to 3/4 ton?
03-28-2011, 07:10 PM | #36 |
Awesome!Thanks for the info!
Jason |
01-25-2013, 10:31 PM | #37 |
Great post - just what I was looking for with good info. Wondering if anyone has some follow up as to how this setup really works? I plan on combining the 50-1007 with the Wilwood 260-11179 proportioning valve on a '72 Jimmy, 14FF and 60 both with discs. Thanks for the info!
03-04-2015, 04:28 AM | #38 |
Hey all. In checking out this great thread, I thought that the booster and master cylinder looked very different in my Blazer, and it is lol. I was looking at the part number to see what it might be. It has a penstar logo, it is Bendix 18268 with pat #3110031 "and others". So I cross referenced these numbers and according to what I found, the booster and master cylinder that was replaced ( by who?) is what they used in a '70 AAR Cuda and 69/70 Charger R/T
Anyone know why they would have done this? These days, a refurbished one of these boosters is big $$$. And then the original appearing master cylinder as well. Just something crazy I realized and was hoping to get some thoughts. |
03-04-2015, 10:05 PM | #39 | |
If it's an original booster master from that Cuda or Charger yes your talking good money.....sell,them and get a free upgrade!
1970 2WD Blazer 454 1972 C-10 Extended Cab 350 SBC |
03-05-2015, 02:42 PM | #40 |
That is exactly what I am thinking . The one ton setup is what I want. And I love the newer style proportion ing valve. Very slick. On your new ones. Did you guys shoot them with clear? Or just install it the way it came? I just don't want it colored "rusty" lol.
04-18-2015, 01:14 PM | #41 |
Active Member
Does anyone have the proportioning valve and brake line product numbers for inlinetube.com?
Thanks Carey |
08-30-2015, 12:59 PM | #42 |
I know this is a little old but I had the same question. I just ordered part No. CTB71MC44 from Inline Tube. When it arrives in about a week I'll report back and confirm the part number.
09-24-2015, 08:33 AM | #43 | |
1967 K30 461/TH400/Np205/D60/14FF/BDS MTZ 375/75/16 on 16x10 Pro Comps |
09-25-2015, 02:26 PM | #44 |
I just wanted to report back on this. The part number I listed above is correct for the crossover.
