01-28-2011, 10:14 PM | #1 |
SKINNY TIRES RULE!
Battery gauge bouncing
The battery gauge needle is bouncing side to side when the truck is at an idle or at a constant speed (bounces more at idle). I also noticed that the dash lights are dimmer when I'm sitting at a stop light than when I accelerate.
Where should I start - Battery or Alternator?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
01-28-2011, 11:42 PM | #2 |
Future TOTM Winner
Re: Battery gauge bouncing
Internally or externally regulated? In my experience if your charging system is in good working order you should be able to remove your battery altogether, throw it in the ditch, and everything will run and perform properly. I would start by checking all the major connections i.e. cables, alternator wire, and main grounds ESPECIALLY the dash panel ground along with the body to frame, engine to frame, engine to body, whatever you may have...maybe at a couple more while you are at it, can't have to many.
EDIT: Have you taken a volt meter and checked the voltage at the battery???
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 01-28-2011 at 11:54 PM. |
01-29-2011, 01:03 AM | #3 |
But in my truck the gauge cluster is bad the mechanic told me he disconnected the fuel pump and my fuel gauge still pegs past full, although for know it returns to the correct fuel level.
_____________________ cars for sale classic cars for sale |
01-29-2011, 03:15 AM | #4 |
voltage regulator kicking on & off. Try a new one.
01-29-2011, 03:28 AM | #5 | |
Sounds reasonable to me that you would have a bouncy gauge in a bouncy truck
Sorry, i couldn't resist the humor in it. Is this a volt gauge or factory ammeter, first thing I would do is verify your voltage readings with a DMM
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
01-29-2011, 04:31 PM | #6 |
Certainly sounds like a faulty regulator to me. Take a volt meter and read the voltage at the battery while it's running. See what it's reading at idle and when revved up.
