01-28-2011, 11:36 PM | #1 |
Chopped crossmember and a/c in a 67/72?
So I am in the process of doing my disk swap in the front of my 70. I got a pancaked crossmember that I want to run, but I also dont want to go swapping to a different a/c setup just yet....Im currious if I can get away with it or if I should leave well enough alone for now?...
I got a 255/55 18 tire on the front and am going to be running a 2.5 drop spindle and it has cupped lowers for it as well...not aginst running stockers again.. Thanks for and advice Jeff |
01-29-2011, 09:51 AM | #2 |
67-72 parts collector,…
Re: Chopped crossmember and a/c in a 67/72?
I think your "firewall side" A/C box will cause you issues with the pancaked crossmember.
I'm not sure of the tire height of your 18's,... but I would try to stay with a 27" tall front tire and your stock crossmember.
01-29-2011, 10:02 AM | #3 |
Here's a good thread.
This is a SWEET Dropmember equipped truck with factory A/C, owned by member 5windowpickup. I belive he did get rid of the factory A/C box,... when he went to billet wheels, to get it to lay out. It's a good read! http://67-72chevytrucks.com/vboard/s...d.php?t=365912
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-29-2011 at 10:03 AM. |
01-29-2011, 10:26 AM | #4 |
If i have done my research wright then there should be no problems with a pancaked crossmember,
If you take a 2" section out then the engine mounts will be in the same place, |
01-29-2011, 10:37 AM | #5 | |
Are you moving the steering box and idler arm up 2" also?
01-29-2011, 10:41 AM | #6 |
Not looked at that yet, i have been trying to find someone who has done this also,
If thats right then i will stop at 1.5" Thanks for the info. |
01-29-2011, 11:08 AM | #7 |
Happy to be here
Contact forum member Capt Kaos. He used to sell the chopped crossmembers and has the straight scoop on what will work. I think Keith is correct that 1.5 is the limit.
Posted via Mobile Device |
01-29-2011, 12:04 PM | #8 |
Thanks for the responses guys, Ive done a fair amount of searching on this seems like 1.5 inches is the limit, and even that is hit or miss so to speak. Think I will just throw it back together with out it and see where it ends up.
Thanks Jeff |
01-29-2011, 12:31 PM | #9 |
You realize we are going to need pictures now. Ha.
02-01-2011, 03:22 AM | #10 |
Tried to contact capt kaos but no reply yet !
? Anyone got any pics of this in situ, |
