Old 01-28-2011, 11:38 PM   #126
67chevy1series
67chevy1series's Avatar
Re: The Fuse is Lit...
allred!!!
67chevy1series is offline   Reply With Quote
Old 01-28-2011, 11:46 PM   #127
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the cab. You can do what you want with your paint. For me I'm going with solid red, so I am kinda partial.
Old 01-29-2011, 11:19 AM   #128
hgs_notes
GEARHEAD
hgs_notes's Avatar
If you go with the white top, also paint the windshield posts and door window frames to match. I would do the grill also if you went that route, but not the bottom of the body.
hgs_notes is offline   Reply With Quote
Old 01-29-2011, 11:24 AM   #129
67cheby
67cheby
67cheby's Avatar
Are you going to be using all of the factory trim , if you are running all of the factory trim i like a white top, if you are shaving all of the trim all red , just my 2 cents
67cheby is offline   Reply With Quote
Old 01-30-2011, 04:47 PM   #130
RocketKing
RocketKing's Avatar
Thanks for the opinions. I am still trying to decide for sure.
Thought you might want to see the undercoating I put on the other day.
Wow, I think I need to use some Windex on that camera lens.
Rex
RocketKing is offline   Reply With Quote
Old 01-30-2011, 04:50 PM   #131
67chevy1series
wow looksa clean!!!
Old 01-30-2011, 05:19 PM   #132
VA72C10
VA72C10
VA72C10's Avatar
nice work...and the lens may not be dirty...if you had just finished spraying it might have picked up the particles in the air...happened to me all the time when documenting my last build...
Old 01-31-2011, 10:11 AM   #133
67cheby
67cheby
67cheby's Avatar
looking good
Old 02-04-2011, 12:22 AM   #134
RocketKing
RocketKing's Avatar
Primer and sand...and sand...and sand.
Rex
Old 02-04-2011, 12:30 AM   #135
mcbassin
Still Learning
mcbassin's Avatar
Diggin the roticerie. I bet that makes it a lot easier hitting the roof. Hey, you got any fingerprints left? Gotta love sanding.
Old 02-04-2011, 12:32 AM   #136
VA72C10
VA72C10
VA72C10's Avatar
Looking good! And I feel your pain with the sanding!!!
Old 02-04-2011, 12:38 AM   #137
67chevy1series
my favorite part of sanding was the door jambs and the roof on the inside! that was fun your lucky you have a big window! less metal.....
Old 02-04-2011, 12:43 AM   #138
RocketKing
RocketKing's Avatar
The rotiserre is the best! First time I have used one and would hate to go back to just sawhorses!
I was just thinkin' in the first post that now would be a good time to rob a bank because I would be hard to fingerprint...lol.
Rex
Old 02-04-2011, 03:21 AM   #139
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work! It is coming along nicely!
Ryan
1969 Chevy milk truck
Old 02-04-2011, 10:22 AM   #140
67cheby
67cheby
67cheby's Avatar
quit typing.....back to sanding, only a few months left until Summer !!!
Old 02-16-2011, 09:31 PM   #141
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Rocketking, Have you test fitted the cab with the engine/trans in place? I tried putting my 4.8/4l80e all the way back like yours and the trans hit the pinch weld on the cab when I tried installing the trans mount. I ended up modifying my adapter plates to both be like your passenger side(1.75" forward). Body work is lookin great by the way!
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-16-2011, 10:43 PM   #142
mcbassin
Still Learning
mcbassin's Avatar
What is the main reason for moving the engine towards the back? Just to close the gap at the firewall or to gain clearence for the cooling fan(s)? thanks
Old 02-17-2011, 10:10 AM   #143
usmcchevy
usmcchevy's Avatar
Room up front and wieght transfer were my reasons for trying, oh and it was easier to put it all of the way back because of the adapter plates i have.
Build thread
LSx Swap FAQ index
Old 02-17-2011, 12:02 PM   #144
RocketKing
RocketKing's Avatar
Not yet. Looks like we will be have the cab painted next week and we will fit then. I have been sweating this very question because I have seen others hit the pinch weld. Glad you were able to fix yours without to much problem.
Thanks for the compliment on the body, I hope the major work on the cab is done!
My main reason was for more clearence up front.
Rex
Old 02-17-2011, 12:10 PM   #145
67cheby
67cheby
67cheby's Avatar
Have the cab painted next week.......wow !!! Smoking me
Old 02-17-2011, 02:50 PM   #146
usmcchevy
usmcchevy's Avatar
I have a pic of how much clearance I have now, but its on my home computer. You could possibly cut the pinch weld off to make clearance, but mine was already hitting with the trans just sitting on the cross member, no trans mount.
Build thread
LSx Swap FAQ index
Old 02-17-2011, 07:08 PM   #147
67chevy1series
your build is coming along great!.......but you have been takin forever!
Old 02-17-2011, 11:11 PM   #148
RocketKing
RocketKing's Avatar
Thanks, but don't feel to bad because it is just the cab. lol
Okay, now I am reeeally sweating it.
Rex
Old 02-18-2011, 02:16 AM   #149
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Great looking build...love the swap!!
How did you prep the intake for paint? Did you remove lots off of it before spraying it or just taped off bits?
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-18-2011, 03:42 AM   #150
Cambons
just did a quick read over looks good so far man good luck
Cambons is offline   Reply With Quote
