ideas on removing tonneau cover
I,m usually by myself and was thinking of a way to remove glass tonneau cover by myself, is a old heavy one.any ideas out there
Re: ideas on removing tonneau cover
anyone,
go to you moms house and have your pop give you a hand.
or, ask a guy at work to help you. or your neigbor. |
Parts and more parts
If you have a standard garage with a ceiling that is low, then connect some eybolts in the joists and use a set of nylon straps to lift the cover from the bed. You can pull it up to a height that you can drive out from under it easily.
Frank |
The One And Only !!!
Raise it up and lay some towels down the bed rails, Lower it down then craw under and unbolt the hinge and supports. Grab the end and slide it off the back, When you get it to the end of the bed rails set that end on the floor/ground. Grab one side and stand it on end then flip it over upside down on the floor/ground on towels etc.
I use to remove/install a glass high top topper on my long bed Toyota all by myself the same way, Once off I'd flip it back over so it wouldn't fill with rain water.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
#6 | |
C35 Crew Dually
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
