Old 07-02-2003, 11:25 AM   #1
case_bt
case_bt's Avatar
Eng miss high rpms
My engine seems to miss when I punch it or when it kicks into passing gear If I stay in it it goes away what could this be?
case_bt is offline   Reply With Quote
Old 07-02-2003, 11:49 AM   #2
jhow66
jhow66's Avatar
What kind of carb, motor?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-02-2003, 12:06 PM   #3
case_bt
case_bt's Avatar
327 4 barrel quad
Old 07-02-2003, 04:04 PM   #4
cdowns
cdowns's Avatar
could be a problem with your distributor, if you still have points system check the points condition or setting or could also be the condensor and or coil or cap or rotor condition,when was the last time you tuned it up last time you changed plugs,plug wires ???these things do need routine maintenance better to change things on a schedule than to wait for them to fail
Old 07-02-2003, 07:32 PM   #5
jhow66
jhow66's Avatar
Back air valves opening too soon. Do you know how to adjust ?
Old 07-02-2003, 07:58 PM   #6
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
I'm with cdowns on this one.
67Fleetsidedream is offline   Reply With Quote
Old 07-02-2003, 08:58 PM   #7
Randy70C-10
Randy70C-10's Avatar
My Model A had a slight miss around 160 mph, but getting rid of the Mallory Unilite and switching to a marine HEI fixed it.
Randy70C-10 is offline   Reply With Quote
Old 07-02-2003, 09:15 PM   #8
RACING29
My dirt track car has the same problem but it sounds like a stutter box at the end of the straight away when it's turning about 6700 RPM. I don't know whats wrong with it any ideas?
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!!
RACING29 is offline   Reply With Quote
Old 07-02-2003, 10:03 PM   #9
RipMeyer
RipMeyer's Avatar
Common occurrence when timing is off.
RipMeyer is offline   Reply With Quote
