Rocker to Front pillar alignment
Hey,
I have been working on my 70 C20 for 3 solid weekends. I welded in a new floor pan and after that I started on the front pillar. It was garbage to begin with so it has not been useful as a reference. I welded in the new front pillar I bought from LMC last night and thought I would use the rocker panel I cut out as a test fit until the new ones get here. The rocker's I cut out were replacement and seem welded in... So I may have tweaked it a bit when cutting it out. I don't know. What I do know is, it is not fitting correctly around the front pillar. Can anyone tell from the pics I posted if I welded in the pillar wrong or maybe I need to trim more off the pillar or maybe I welded in the floor pan wrong and it's pushing the area out. I just don't know. Thanks for any advice you can lend. Joshua |
Re: Rocker to Front pillar alignment
BTW, I have been reading many of the previous posts on similar problems. I just have found good pics of what the front and profile views should look like. That is why I posted them and maybe someone who knows what it should look like will be able to tell what my problem is.
J |
I had trouble getting my LH rocker to fit and i had the original pillar, i had to tweak it for a while to get it to fit and then just weld it up. I found the most important thing is to have the door on the whole time for a good reference.
