spring rate?
What spring rate are u guys runing on rear coilovers for street use. im runin 72 swb 4 link
![]() Join Date: Jul 2010
Re: spring rate?
It depends on shock lenght. As a golden rule, I try to get 5" of static spring compression at Ride hieght. The rear of a c-10 is about 1500 lbs. half per side = 700. If you could get 5" of static compression, that would be a 120 lb spring. Most set-ups won't allow for that, 3" to 3 1/2" is more realistic, 700 div. by 3 = 233lbs/in spring, or 700 div. by 3 1/2 = 200lbs/in spring.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
Re: spring rate?
thanks 4 the info i been reading up on your make it handle thread been lots of help
Re: spring rate?
Also consider the angle of the coilovers, that will play a factor in the spring rate as well.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
