01-31-2011, 07:24 AM | #1 |
65 suburban vortec 5.3 bagged
where to cut the frame to make a long wheel base to a short wheel base?
i will be doing this soon and was wondering if anyone has done this and can recommend where to cut the frame i thought the show Trucks!!! on Spike did it and i cant find the video any way any help would be awesome!!thanks
01-31-2011, 08:37 AM | #2 |
Re: where to cut the frame to make a long wheel base to a short wheel base?
Trucks! did do a show on it. You can watch it on demand here http://www.amazon.com/gp/product/B000RCNPIA
Classic Trucks did it here http://www.classictrucks.com/tech/cl...uck/index.html Early Classic did it here http://www.earlyclassic.com/tech.asp...20No!-Shortbed There is a few threads on it and members that did it on the forum too, the articles and video show you where and how much to cut. Some of them cut in different areas but they all take a total of 20 inches out of the frame. 8 right off the back and 12 usually under the cab where the frame rails are straight. Last edited by helipirate; 01-31-2011 at 03:55 PM. |
01-31-2011, 10:18 AM | #3 |
thanks that is what i was looking for time to warm up the sawsall!!!
01-31-2011, 10:37 AM | #4 |
Happy to be here
Check our FAQ forum. There are a couple of well written articles there too.
01-31-2011, 03:18 PM | #5 |
When I cut mine I tok 12 inches out ahead of the rear cab mount (mover cab mounty back 12 inches) and then took 6 inches off teh rear of the frame.
I chose to make the cut ahead of the rear cab mount because the frame is uniform and straight at that point. Put in an 18 inch plate on teh inside of teh frame to form a box frame centered over the cut. Left the crossmember in place and put in a one peice driveshaft. Made for a very easy job and great result. regards Luc
65 burb On the road Mar 26th Finally |
01-31-2011, 04:43 PM | #6 |
I just went out and found a rolling swb frame, took all the stuff of the lwb and put it on the swb,,,,,,much less work......cost $175.00 also got a complete front clip, cab with doors, and a fleetside be with tailgate.....Kieth
01-31-2011, 06:37 PM | #7 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
01-31-2011, 10:02 PM | #8 |
awesome thanks for all of the info from everyone!!!!!
