Closed Thread
Old 02-01-2011, 10:08 AM   #2501
towersddg9
towersddg9's Avatar
Re: What did you do to your truck today?
Originally Posted by markeb01 View Post
I really like the custom filler panel on the cowl. I've never seen that done before. Nice work.
Thanks markeb01, here is an update
towersddg9 is offline
Old 02-01-2011, 12:24 PM   #2502
Chevy Fleetside
Chevy Fleetside's Avatar
You mean to say you have not seem my pictures before. I am in the process of running the wires right now. They exit the cab from the old gas pedal hole. I am going with a cable instead of the rod.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 02-01-2011, 03:41 PM   #2503
REDNOSE65
REDNOSE65's Avatar
Originally Posted by towersddg9 View Post
Picked up my block and heads from the machine shop $$$$
Dam, speaking of "Moving right along!!!"
You're doing a fine job Rex.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
The making of a Red Nose...
http://www.67-72chevytrucks.com/vboa...d.php?t=396518
REDNOSE65 is offline
Old 02-01-2011, 09:13 PM   #2504
steverino66
Made progress on Frankenstein fender (making one good one from best - rust free - parts of 2) - now ready to weld together!
The last pic shows brace/mount of old original (note custom p.o. screw repair at top)
steverino66 is offline
Old 02-01-2011, 09:34 PM   #2505
markeb01
Senior Enthusiast
markeb01's Avatar
I know I’ve seen that photo for sure, but since it’s all smoothed off and painted I never noticed the missing plate. I really like the look, I think I’ll do it to mine when I pull the engine for replacement and detailing of the engine compartment.
markeb01 is offline
Old 02-02-2011, 12:29 AM   #2506
narx66gmc
decided which seat of the two i should use and test fit it. test fit the heater unit under the dash, but decided to mount it in the glove box, pix in a few days... and drew the shop logo on the tailgate with sharpie marker...
Build Thread - Papa's truck build up
narx66gmc is offline
Old 02-02-2011, 01:03 AM   #2507
Bugeyev8
Bugeyev8's Avatar
been there done that !!
Bugeyev8 is offline
Old 02-02-2011, 04:03 AM   #2508
markeb01
Senior Enthusiast
markeb01's Avatar
Nice work. I admire that kind of talent.
markeb01 is offline
Old 02-02-2011, 11:26 AM   #2509
steverino66
I agree - looks great, bugeye. We'll see if my welding project comes out as well in a few days (ran out of time on my snow day yesterday).
Old 02-03-2011, 11:30 PM   #2510
RoyL
RoyL's Avatar
gathering up parts, material for the weekend. The no fun part, but necessary. Nothing worse than a trip to the parts store in the middle of trying to make progress.
Roy
1965 Suburban
Waiting on Time and Money
RoyL is offline
Old 02-04-2011, 12:09 AM   #2511
stealth_weapons
i got mine stuck in the 23 inches of snow we got here.... not as fun as you might think. luckily i have a 4x4 Tahoe for backup
stealth_weapons is offline
Old 02-05-2011, 04:35 AM   #2512
old cruiser
old cruiser's Avatar
I got my 64 registered yesterday and lowered the front 1 more inch today
old cruiser is offline
Old 02-05-2011, 05:06 AM   #2513
92GMCDriver
92GMCDriver's Avatar
I dont own a 60-66 but i picked up some plugs and wires and replaced my fuel pump relay on my 92
92GMCDriver is offline
Old 02-05-2011, 03:03 PM   #2514
Andice
Andice's Avatar
Too cold around here lately to do any work on the truck. This year my focus will be on the floorboards, rockers, seat and window/door seals and gaskets.
Andice is offline
Old 02-05-2011, 07:13 PM   #2515
lakeroadster
Fabricated and installed some custom upper rear shock brackets. A bolt in deal that uses the stock bracket rivet holes. These move the top of the shock back about 4 inches and thus makes the shock about 18 degrees off vertical. Needed because I have 5" drop springs.
I posted a step-by-step procedure with pictures and a drawing... see post #59 of my build thread.
lakeroadster is offline
Old 02-06-2011, 02:00 PM   #2516
Hipper
Hipper's Avatar
still did nothing on either of my trucks but did get the boys 89 trans am running so my projects are getting closer on the list.
71 GMC Long Bed, 454,factory everything, lowered, and shaved.
64 GMC Short Bed (great grandfathers truck)
65 Chevy 1 ton Dually a/c p/s p/b v8 auto
89 Jeep Cherokee 3" lift
79 MG Midget (My 7 year old vehicle)
29 Ford Model A Rat Rod (in the works)
86 pontiac fiero 2.5 manual18 year olds)
87 pontiac fiero SE 2.8 auto (18 year olds)
90 Mitsubishi eclipes turbo AWD (18 year olds)
69 BMW 1600 (wifes toy)
Hipper is offline
Old 02-06-2011, 04:39 PM   #2517
70inline6
Pulled the carb parts out of the carb cleaner bucket and rebuilt it. I'm surprised it ran before... float must have been dragging on the bottom of the bowl and the metering rod was unhooked from the pump plunger rod...
Inlet is partially stripped. If it leaks, I'll find a Rochester mono...
70inline6 is offline
Old 02-06-2011, 10:49 PM   #2518
tenni126
Finished installing the three point retractable seat belts, cleaned up some more wiring, got my heater working (with two speeds now!) and got all the new window felts put in...starting to get pretty close to civilized!!! Also pulled the clutch pedal and z-bar out. Next up, a stereo to take care of the rest of the rattles and squeaks, still waiting for the new lock set to come in from ECE. Still have to get the rear axles drilled to 5x5, find a power steering setup, decide what to do about A/C, and install the rear discs. Whew. And i finally got around to test fitting the hitch reciever from uhaul. Should work fine. This things never gonna be done!!
tenni126 is offline
Old 02-07-2011, 12:31 AM   #2519
Bugeyev8
Bugeyev8's Avatar
they sell a repair fitting for that, its a bit longer and will fix the leak if there is one
Bugeyev8 is offline
Old 02-07-2011, 01:33 AM   #2520
sasquatch5308
sasquatch5308's Avatar
Messed around with my throttle linkage a little bit. Having a bit of a brain fart, is the pedal assembly different in a 62 than it would be in a 66? I put a 250 where the 235 was.
safety third!
1962 swb 4x4
1952 Chevy "turd bucket" truck
1953 Buick special
1953 Famous James motorcycle
1975 Scout II
sasquatch5308 is offline
Old 02-07-2011, 05:40 AM   #2521
Vics63Chevy
Vics63Chevy's Avatar
Replaced tires all around so I can tow my truck to the shop to start tearing into it
Vics63Chevy is offline
Old 02-07-2011, 12:36 PM   #2522
knuckledragger
knuckledragger's Avatar
Mounted my tank,cleaned and repaired the tailights,finished one side of the notch,prepped the drive shaft for cutting,built a mount for the prop valve,mocked up the p/s pressure hose,started mounting all of the hardlines.Good productive day!
65 c-10 swb,bbw,step,402/t350,sold!!
1979 c10 Silverado,250,auto,gonna have a 3/5 drop,and twice pipes!Sold
Bought the wife a 84 gmc short step
knuckledragger is offline
Old 02-07-2011, 01:03 PM   #2523
smilts60
Im waiting on a clutch flywheel for my 94 mustang GT so i can get it out of the shop and actually work on my 60 lwb.
smilts60 is offline
Old 02-07-2011, 04:13 PM   #2524
jbgroby
jbgroby's Avatar
Was able to bring her home this morning, she where she belongs Boys! The guy in the hat is Uncle Ken, he's into antique too has a (I think a '68-69) TR6 rag top fully restored. I really need to put the seat in to get it off the pool table before the wife saw it and it's also out of the way too. I knew I was clos to the color match, but I really think I could not gotten any closer, esp. right out of the catalog from the Truck and Car Shop.
jbgroby is offline
Old 02-07-2011, 06:24 PM   #2525
onequickchevy
onequickchevy's Avatar
Well, yesterday actually. My wife said that I needed to be sure the old truck was clean. When I asked her why, she just smiled and said that we were going to use it as a prop in our family portraits. Too cool, made this alot more fun than it could have been.
Slowly but surely getting it done.
onequickchevy is offline
Closed Thread
