Old 02-02-2011, 08:02 PM   #1
gimmy 64
my rear end
i know this has been asked before but i have a gmc and trying to figure rear end ratio. i thought maybe GMC guys would chime in--mark-- anyway i get three and a half turns on drive shaft with one revolution of wheel. any body have same ratio? thanks
gimmy 64 is offline   Reply With Quote
Old 02-02-2011, 08:11 PM   #2
daverod
SSN 706
daverod's Avatar
Re: my rear end
there should be a code on top of the axle tube you can find out that way also.
daverod is offline   Reply With Quote
Old 02-02-2011, 08:27 PM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: my rear end
There should be a tag on there showing the gear ratio. The rear ends have stamped ID's as well.
Raise and support the rear of the truck with jack stands.
Read the metal tag attached to one of the differential cover bolts.
This tag, which is always present (if not removed by a previous owner), will indicate the gear ratio that came with the vehicle originally.
This tag may not be valid if the previous owner has changed the ratio, and you will have to remove the cover to find the gear ratio.
1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
http://67-72chevytrucks.com/vboard/s....php?p=4359596
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-02-2011, 09:33 PM   #4
gimmy 64
Re: my rear end
this is why i asked for the gmc guys this is a dana 44 no tags or stamps on axle tube. there are some stampings on the rear housing but i looked them up and they are patent # i do have a number on lower right flange of rear end that is 44-1
Old 02-02-2011, 09:44 PM   #5
Big Fenders
Re: my rear end
How I was taught to determine rear end ration is this..Jack up one wheel, mark pinon flange and then rotate the free wheel exactly two rotations while looking at and counting the pinon flange rotations...best done with two people. Divide one by the other to determine ratio...
Bob
Big Fenders is offline   Reply With Quote
Old 02-03-2011, 01:45 AM   #6
Captainfab
60-66 Nut
Re: my rear end
The Dana 44's were available with 3.54 gears.......
Old 02-03-2011, 04:59 PM   #7
gimmy 64
Re: my rear end
i think you are right capn went to gmc sight and 3:54 posi was an option. thanks guys
