Old 02-04-2011, 01:42 AM   #1
Mattman2010
Mattman2010's Avatar
TH400/NP208 to NP205
I have a TH400/NP208 combo, I found a guy selling a NP205 off of a TH400 and was wondering if I should be able to pull the NP208 off of my transmission and be able to bolt the NP205 right up to it.
Thanks, Matt
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 02-04-2011, 02:03 AM   #2
csb#356
Re: TH400/NP208 to NP205
If he's giving you the adapter with it then you will be able to but the adapter is different for a 208 and 205
csb#356 is offline   Reply With Quote
Old 02-04-2011, 02:07 AM   #3
Mattman2010
Well I am getting the TH400/Adaptor/NP205 TQ and drive shafts from the guy, but my TH400 I have is a good unit and has had all the filters and seals replaced so I would like to use mine as I know it is good and just want to keep the other TH400 for a spare.
Build Thread
Build Thread
Thread
Old 02-04-2011, 10:04 AM   #4
ghettoluxury
ghettoluxury's Avatar
You can bolt that transfer case up to your 2wd TH400 after you remove the tail shaft housing. This will allow you to sell the 400/208 combo to regain some cash.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-04-2011, 10:20 AM   #5
Mattman2010
Well I am planning on buying the whole TH400/NP205 combo ($450), so I will end up with two 4wd TH400 transmissions. As for the 2wd th400, I traded that and the 454 off for a 6.2 diesel and the th400/np208 combo. So I might just use the Th400 off the 208 and then bolt the th400 off the 205 to the 208 and sell them off. Or just keep the other th400 for a spare.
Planning on going to look/buy it tomorrow morning. I was just wanting to make sure that the 205 would bolt up to the th400 that I have the 208 hooked up to because that transmission is good, and idk the shape of this one that is coming with the 205.
Build Thread
Build Thread
Thread
