Old 02-04-2011, 10:21 AM   #1
68jimmy
68jimmy's Avatar
Alternator - what years interchange
Excuse me if this has been answered previously. I just inherited a 78 with the 350/Th350 and the alternator bearing is screaming like a banshee. What model years will work in this situation? It is the standard v-belt setup...
Thanks in advance.
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 02-04-2011, 12:19 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Alternator - what years interchange
Upgrade to a 84-86 100 amp alternator from a Camaro.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-04-2011, 12:30 PM   #3
MARKDTN
The 10SI and then the 12SI alternator was used from 69 into the 80s in all GM cars. It is a good alternator if you don't try to get too much power out of it. It was replaced by the CS series in the 80s. The CS130 is not a very reliable alternator. The CS144 is much better. The common "application" for these is '95-96 Caprice and Roadmaster. There is a harness available so you can plug a CS alternator in where a SI was.
Bottom line, if you just need 50-80 amps or so the SI is fine. If you have fans and big stereo you will want to jump up to a CS144. Be careful when you do this that you do not overpower the wire to the battery. Also you can't use the big alternators with factory ammeters.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 02-04-2011, 12:31 PM   #4
rfmaster
rfmaster's Avatar
Your Current alternator is 62Amp 10SI
15SI from 80's camaro is a direct plug-in - bolt on.
With a little bit more work CS-144 from 90's cady will also work. CS-144 is 100+ Amp alternator with excellent low RPM current capability - real handy if you have electric fans, lights galore or a winch. CS-144 is slightly larger requiring upper bracket work, pulley needs to be swapped out (rib to V-belt) and there is a minor wiring modification (L- wire needs 150 to 300Ohm resistor and connector is different). At $25 from local pick JY it is a low cost upgrade.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 02-04-2011, 12:53 PM   #5
Toxic Redline
Toxic Redline's Avatar
If your looking to save money just go get one from autozone with a lifetime warranty, im still using the warranty my dad got in 85 for his k10 and we have them on all kinds of trucks, we even put them on our john deere tractors we just swapp out the pully.
84 K20 Long Box W.I.P
78 Burb - parts now [Rolled]
68 c20 dump bed
WHEN IN DOUBT--- FLOOR IT
Toxic Redline is offline   Reply With Quote
Old 02-04-2011, 01:21 PM   #6
68jimmy
68jimmy's Avatar
Thanks for all the great info. If it warms up tomorrow I'll see what I can find.
Old 02-05-2011, 10:48 PM   #7
68jimmy
68jimmy's Avatar
I was able to go to the local u-pull it yard and found a 77 cadillac deville with what appeared to be a fairly new alternator. Other than than the lower bracket mounting holes it fit like a glove. And it no longer sounds like a banshee at startup...
