#26 |
VA72C10
![]() Join Date: Mar 2008
Re: How to: Ruin a perfectly good C10
Love it! Ruined it good
![]() Thanks for the interesting write-up and pictures. Now get back out there and ruin it some more ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#27 |
Tot Roddin'
What did you use to mount the bedsides to the raised bed floor?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#28 | ||
A guy with a truck
![]() Quote:
With the bedsides removed, I cut the inner bedside floor mounting flanges off about 1.5" up from the bend, drilled holes through them at evenly spaced intervals, then plug welded them to the opposite bedside in the same position, just flipped 180*, and 3" higher than stock. I used the right side pieces on the left and vice-versa. Same process with the header panel. I also had to take 3" out of the rear stake pockets where they mount to the floor and moved the spot-welded 'L' brackets up. This way, the floor stays whole and you still have all of the rear cross-sill mounting bolts securing the bedsides. I've seen where people cut the floor at the rear corners and leave the stake pockets intact, but I didn't like the idea of the bedsides flexing or bowing outwards causing tailgate alignment issues since these trucks tend to do that in a stock configuration, not to mention modified. I still need to pull it apart again to finalize some things; when I do, I will try to remember to take some pictures. This is not for the faint of heart, as you are hacking up perfectly good bedsides, so you'd better be committed. Some think I should be committed ![]() I think it looks stock enough that most don't catch it and I don't lose any noticeable capacity. Many ways to skin this cat, but I think 3" is a good height since the tubs come to just under the upper body line of the inner bedside; any more than this is doable, but would turn into a lot of sheetmetal work. I have hauled a ton of crap in this bed and it stands up to the abuse- no worries about using this truck as a truck- even with the raised floor...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#29 |
Sofa King Crazy!!
That bed looks stock! Do we get to see a pic with the tailgate down also???? I enjoy watching you ruin stuff.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#30 |
A guy with a truck
Wish I'd known you wanted one, I pulled the gate off today. There is a 3" step from the gate to the floor.
#31 |
A guy with a truck
Baby steps today...
Once I raised the bed floor, the wheel tubs would not sit flush against the inner bedsides since they are 3" above the stock cutout. There is a lip on the tubs that keeps them from fitting all the way to the bed. After removing the tubs (what a pain, these fasteners rust quickly), I proceeded to remove the offending metal with my trusty angle grinder/cutoff wheel.
#32 |
![]() Join Date: Feb 2011
I'm ruining a perfectly good one myself!!!!!! But I think I'm doing what should be done!!!!!! Plus it's mine!!!!!! I love the mods!!!!!! i'm glad you changed that bed back I must admit!!!!!!
#33 |
A guy with a truck
Also had to create a little notch where the body line was preventing the bottom of the tubs from sitting flush. Note the placement of the new mounting holes 3" higher than stock. They fit MUCH better now
![]() My Blazer tank parts did not come in today as scheduled due to inclement weather... ![]()
#34 |
VA72C10
Nice work!
#35 |
Hey, I like that bed lift idea. Seems like it worked well
#36 |
Has more rust than truck...
Awesome work, subscribing.
#37 |
#38 |
67cheby
![]() Join Date: Sep 2008
Nice work
#39 |
subscribed, keep on ruining it.
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
#40 |
Just watching
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
#41 |
Dr. Frankentruck's Monster
![]() Join Date: Aug 2007
You make it look so easy! I hate you!
I'm not prejudiced, I hate everyone. Project SLOMO http://67-72chevytrucks.com/vboard/s...d.php?t=430494 |
#42 |
awesome job on the rasied floor bed! .....thanks for not ruining it by putting that other box back on!!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#43 |
![]() Join Date: Nov 2010
Great work! That raised bed looks factory.
#44 |
chevy runs deep
Nice work
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
#45 |
A guy with a truck
Thanks to all who have posted- you guys keep me motivated
![]() Any of you following my '72 Blazer build know that I parted ways with it, not necessarily by choice, but for good reason. It was like pulling off a band-aid, you don't really want to, but you know you have to, so the wound will properly heal... Between that time and now, I have managed to piece my life back together and am stable and headed in a new direction, which gives me an opportunity to think about playing in the garage again ![]() ![]() The snag is, it can't just get painted and appear complete, it must be road-worthy, capable of some fairly long distance interstate travel while also being reliable and semi-comfortable. We are to be married in June, so that leaves a small window to get everything done in, and necessitates the installation of the Classic Auto Air kit I have sitting on a shelf... I have started putting together a punch list of items that need to be completed to make it happen. The hard part is finding the balance between what needs to be done and what I want to do, and without cutting corners. Luckily, I have most of the parts already and the required funds for completion are being added to the wedding budget ![]() Sorry for the long, drawn-out, lack-of-update post. I wanted to put this out there, so hopefully you guys can hold me accountable ![]() ...and yes, I am one lucky guy. I am very blessed to have found such a wonderful woman who wants to integrate the things I like into our life together. Another upside is that since the truck will now be 'a part of the family', she won't ever ask me to sell it ![]()
#46 |
VA72C10
I'll be here to remind you whever you are slacking!
![]() ![]() Congrats on the upcoming marriage!!!!
#47 |
nice build, will be watching
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
#48 |
very nice project! was going to build a daily driver, but somewhere got sucked in to going the full mile. keep up the progress.
#49 |
A guy with a truck
Managed a half a day off work today
![]() The first couple of pics show the state of the front end when I started. ![]()
#50 |
A guy with a truck
Here's a few more of the progress, including a crappy cell phone pic of the truck on stands that I sent to my fiance when she asked what I was doing today
![]() The 'new' parts were cleaned, painted with rust encapsulator and chassis black, and rebuilt today. The lowers are a set I picked up a while back which got new balljoints; the uppers are actually the same ones from the previous post that I removed earlier today, just cleaned, painted and with new Moog offset cross-shafts and balljoints. The 1.25" anti-sway bar, poly bushings, and ECE lowered mounts are more hand-me-downs from the Blazer that have been sitting on the shelf for a while. The springs are new Moog 6102s that I picked up on Amazon for $40! I love me some free super saver shipping! They will be losing a full round tomorrow before installation ![]()
